Old 08-22-2016, 05:56 PM   #1
JohnKimble
Courtesy light switch wire suck behind hole...
Today I was removing my passenger side courtesy light switch as it was rusted closed. Once I began to remove the switch, the orange wire popped right off and back through the threaded hole, leaving me with only a white wire exposed.
Is it possible to gain access below the passenger kick panel to feed this orange wire back through the hole, or am I screwed?
JohnKimble is offline   Reply With Quote
Old 08-22-2016, 07:00 PM   #2
JohnKimble
Re: Courtesy light switch wire suck behind hole...
Disregard. It turns on the passenger side only has a white wire because that's where the circuit ends. Could have swore it had an orange wire like the drivers side...
