Vacumm guage 87 Silverado
Bought a fully loaded 87 Silverado today. Has vacuum guage in far left bottom guage hole. Also has color match floor mat option and the mats are still in truck in nice condition. Factory tow hooks on front with air dam? 2wd truck. The option list in glove box is two full columns.
Member # 286 1975 Trans Am 1986 GMC Wrangler 4X4 1985 Silverado K30 Dually 2016 Skidoo Renegade XRS 800 2016 Yamaha Grizzly 700 |
Re: Vacumm guage 87 Silverado
Congratulations on the new truck....but we need pictures
![]() Join Date: Oct 2014
Yes pictures, and congrats on the purchase
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
I am using it for a parts truck. LOL. I am building a K30 and wanted all the options from this truck. It is unmolested and the A/C works. So the truck was worth the $2500. Part out the rest of it.
Here are some photos. I have never seen another Vac guage in these trucks.
Cannot seem to post photos straight up. Do not know why. they are normal when I look at them on my system.
That's pretty cheap for up there. I'll bet that vacuum gauge is just as accurate as the temp gauge.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
I think they only came in the c60's and c70's. I wonder if someone has swapped the cluster?
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
I have seen air pressure gauges in this spot on the C50 and 60 etc trucks. Never a VAC guage.
Fuelster, the only way to tell if it came factory on the truck is to look at the SPID (factory build sheet) in the glove box. I've seen the VAC gauge in the bigger C40-C60 trucks, but never a C10/C20/C30. I made up a large tach, small fuel gauge under it, and a clock on the left; gauge cluster for my truck. It can be done.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
I have both types of tachs. One with the fuel guage in it and another cluster with the fuel guage where the VAC guage is. There are option numbers on the SPID that I cannot find. If I knew what the option number is for VAC guage I could check for that number on the SPID.
If you're going to be needing new harnesses I've got ya covered there! Wow that truck is clean btw-I don't know that I could knock it in the head myself....but either way, have fun!!
#13 |
I do need a tach harness. The tach I will be using is the tach without the fuel guage in it. I think there is a tach filter also required. I will probably rig up the VAC guage in another cluster with the Tach/Fuel guage and sell it.
#14 |
Yep I have them too-nobody offers them with a filter which is weird.
#15 |
I think Keith Seymour would be the best person to ask about this since he was so involved in the production.
I looked at the light duty service manual that Hatzie has for reference. There is no RPO code that I can see that includes a vacuum gauge on the light duty pickups. Z53 - GAUGE PACKAGE - VOLTMETER, OIL PRESS. AND TEMP This is the only RPO code listed there that mentions gauges. This website: http://www.47287chevytrucks.com/pg4.html Lists the following RPO code: J81 VACUUM RESERVE TANK GAUGE You might want to look through your SPID or post it here and see if something matches it to see if it's factory or not. I'd be interested to know what it's even hooked up to. Just as a for instance...my truck has what looks to be a factory sliding rear window. It's marked PPG and Soft-Ray just like my other windows but my SPID is missing RPO code A28. So I think it was added after the truck was purchased and it is probably original but not original to the truck. |
#16 |
This truck has the A28 on the spid. And the glass is marked that same as yours. Black frame, tinted glass in it.
#17 |
This must be OEM original and not added. The VAC guage is hooked to the intake manifold, thru a valve, thru a y, to a bracket fastened to the firewall into a steel pipe with a grommet in the firewall to the guage. Interesting.
#18 |
Options on spid are,
A28, CD4, D45,F51,F60,G51,J55,K34,MX1(T400),N33,N67(Has Aluminum wheels),TT5,UF2,VF1,XFM,YFM,ZF1,ZY3,72U,A01,B32,C60,E63,F59,GU4,G80,K05,L03,NL2,N41,P11,UA1,UM6,W78, YE9,ZFM,ZQ2,Z49,77D There you go.
#19 |
The VIN is odd too. 1GCER14H9HF300100. 100th 87 built??
#20 |
G80 means Posi....prolly a 4.10 Posi rear!
#21 |
GU4 3.08 gears
#22 |
Getting Old; Going Broke
I don't think that N67 is aluminum wheels.
You guys sure the G80 is posi? I guess I do leave 2 black marks, but not if doing donuts I don't think. Anyways, as everyone has said, that vacuum gauge is a transplant. Post a picture of the SPID, it's easy.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
#23 |
#24 |
Vac guage is not a transplant. It is too unmolested and correct to be in my opinion. There are option numbers that I cannot find and it may be one of those. There are strange things that happen. Options on a truck without the code on the spid. This spid is full top to bottom both sides. Maybe there was not enough room and they said F it. LOL Who knows. This truck was never restored and is virgin.
#25 |
Well more accurately G80 is limited slip.
