Old 08-22-2016, 08:23 PM   #1
Bthomas67wagon
79 chevy k10
Hello all.
Im trying to buy a 1979 K20 for my son.
BUT the one im looking at needs spring mounts and im concerned about a hole of two in frame next to mounts.
I dont mind cutting and welding, but are parts available?
Needs about 10 patch panels and am concerned w how much illhave into it afterwards. :/
Bthomas67wagon is offline   Reply With Quote
Old 08-22-2016, 08:24 PM   #2
tommy217xxx
tommy217xxx's Avatar
Re: 79 chevy k10
U can replace every part on these trucks. But like u said, is it gonna cost more then u want. I would start by googling the truck and parts. I should see places like lmc and many others. See what u need for parts and go from there.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 08-23-2016, 01:18 AM   #3
Dcheat
Re: 79 chevy k10
10 patch panels? Wow.. If you found that many areas that need work, image what you would find once you get it home. I'd pass on that rig. But thats just me.
patching the frame sections is simple enough. If you're looking for replacement bits for the suspension, check out DIY4X
http://diy4x.com/product.php?product...cat=250&page=1
Dcheat is offline   Reply With Quote
Old 08-23-2016, 08:07 AM   #4
cadillac_al
Re: 79 chevy k10
It sounds like it would be cheaper to take a road trip to the southwest US and buy one that doesn't need so much work. Now if you want to teach your son rust repair and welding, a rust bucket would be the ticket.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-23-2016, 01:26 PM   #5
rgunlock
rgunlock's Avatar
Re: 79 chevy k10
I did a lot of rust repair on the truck in my signature. In my own experience, other than the cab floor, wherever I had rust through on the surface, there was also a backside panel of some sort that generally had even more rust. As an example, I had rust around the heater box on the firewall. Went to fix that and found more rust behind it in the cowl area. If you see rust in the wheel well in the battery area, then you likely also have a lot of rust in the lower part of the core support in that area.
You don't find many patch panels for the out-of-sight sheetmetal so you'll have to fabricate. Good news is nobody is likely to see your work back there so it doesn't have to look perfect. Point is like the other guy said, you'll likely find more rust when you get it home and look closer, then even more when you start cutting out the rot that you see. You'll need to figure that in when you decide how much work to put into the truck.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is online now   Reply With Quote
