tommy . master of madness
rotor ?
Firefighter
Probably a spindle swap would be the best, altough I have seen in a magazine somewhere where they installed oversized or undersized (I can't remember which) bearings. But to me the spindle swap sounds a little safer.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Firefighter
Or you could have them redrilled with the 6 bolt pattern, or have your rearend axles redrilled to the 5 bolt pattern.
its all about the +6 inches
I am pretty sure GMC Paul sells 6 lug rotors.
Fabricate till you "puke"
If you have the heavy(1.250 thick ) rotors, you can bolt on the aftermarket 6 lug rotors. Check with GMC paul, as Andy has suggested. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
