08-22-2016, 09:39 PM | #1 |
69cst10 suspension
I have a 69cst10 LB with coil springs and helper spring leaf on the rear but not much weight support back there. I do not mind spending what is necessary to add more support as funding will come from kids inheritance. I tried faq so please do not bore me with that. I am 83 so be nice.
08-23-2016, 08:20 AM | #2 |
Re: 69cst10 suspension
Coil spring truck? You can get load increasing airbags. (NOT the same as the airbag setups guys use to lower the truck!)
You could also swap 1/2 ton springs for 3/4 ton springs. HD shocks are good as well.
08-23-2016, 11:01 AM | #3 |
