Old 08-23-2016, 02:58 PM   #1
Brad54
Brad54's Avatar
High humps and low humps: which way is the conversion usually done?
I got to thinking about this the other day: I usually see the high hump tunnels and the firewall piece for sale, but rarely see the low-hump pieces for sale.
Did I miss it, or do most of the trans tunnel conversions go from low hump to installing a high hump?
Does the low hump clear a modern auto trans?
Why do most guys install the high humps? My suburban came with the high hump and a 4spd granny, and my k20 came with a high hump but a 3spd manual on the column.
OR, do I have it backwards, and guys install the low humps in place of the high humps?
(And while I'm at it, what year did they change from bolt-in to a welded in piece of the floor?)
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 08-23-2016, 04:46 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: High humps and low humps: which way is the conversion usually done?
I have a 200R4 with a 350 set up in a low hump cab, so I don't know for sure why. Maybe the LS guys need it.
Old 08-23-2016, 05:08 PM   #3
Joemomma1
Joemomma1's Avatar
From what I've seen it's low to high than people are after. It may be for clearance issues but I don't fire sure know why people do it. My truck had the high hump but our low hump truck fits a auto tranny just fine.
Joemomma1 is offline   Reply With Quote
Old 08-23-2016, 10:37 PM   #4
pestwagon
Low humps were for AT trucks. They are rarer than 3 and 4 speed trucks. So in junkyards if you want to convert to a low hump floor from a original 4 speed high hump I looked at a lot of trucks this year before I found a good low hump floor to use.
I think the guys slamming theire trucks down with air ride might want the high humps for clearences.
pestwagon is offline   Reply With Quote
Old 08-23-2016, 11:05 PM   #5
Joemomma1
Joemomma1's Avatar
We've had and seen plenty of tree shifting trucks with low hump. So it's probably not exclusive to the auto trucks
Old 08-24-2016, 10:16 AM   #6
66ChevyMax
66ChevyMax's Avatar
My truck was originally a 3 on the tree with low hump!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 08-24-2016, 11:07 AM   #7
aerotruk63
aerotruk63's Avatar
The low hump was for Auto and 3 Speed Manual.
4 speed manual had the High Hump.
In some years on the Medium Duty trucks the the front section was also removable.
1963 C60 shown.
Old 08-24-2016, 12:39 PM   #8
theastronaut
theastronaut's Avatar
I'm building a bagged '66 and need to swap to a high hump to clear the T56 six speed.
theastronaut is offline   Reply With Quote
Old 08-24-2016, 12:49 PM   #9
scoot_mcgrute
Do you need the high hump to clear the T56 because you are bagging it or does it look like a more conventional setup need a high hump as well?
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 08-24-2016, 12:53 PM   #10
theastronaut
I believe you can barely stuff in a T56 under a low hump floor if you're stock height or doing a static drop. I have mine mocked up and the low hump is holding the cab from dropping all the way down when it's aired out.
Old 08-24-2016, 12:57 PM   #11
LVPhotos
LVPhotos's Avatar
My 1962 came v8 3 on tree, small hump. First cut was floor shift conversion, 2nd my hack to fit T5 (didn't have weld skills or machine ) 3rd was high hump for TKO 600 and PORTERBUILT up and forward movement. And yes my low hump was bolt in.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-24-2016, 10:19 PM   #12
andyh1956
Has anyone changed from a low hump to a high hump & bolted the front section of the high hump in? I'm gonna be using an NV4500 trans & thought it might be an advantage down the road sometime to have it bolted in.
andyh1956 is offline   Reply With Quote
Old 08-25-2016, 08:23 PM   #13
66Submarine
66Submarine's Avatar
http://www.6066gmcguy.com/3-to-4-speed.html
Kind of. My hands are bleeding just thinking of all the sheet metal screws! Don't see any reason you can't bolt it in if you want to.
Are you going to use the NV4500 bellhousing?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 08-25-2016, 10:31 PM   #14
Blue666(2)
I went from a low hump to high hump because I liked the look better. My A833 trans fit with tight clearance under the low but I liked the look of the high hump.
Blue666(2) is offline   Reply With Quote
Old 08-25-2016, 10:54 PM   #15
andyh1956
No I am gonna spring for the Advance Adapters housing that puts the clutch linkage on the driver's side because mine is 4WD.
If I bolt the front section down I will weld nuts on the bottom just like the rear section is fastened, I don't like those pointy sheet metal screws either!
Old 12-30-2019, 09:05 PM   #16
Cricket59
The high humps were mostly needed for the Big Block motors with 400TH
Cricket59 is offline   Reply With Quote
Old 12-30-2019, 10:51 PM   #17
Captainfab
60-66 Nut
I have a big block & TH400 in my '66 Suburban with a low hump.
Old 12-30-2019, 11:47 PM   #18
'63GENIII
'63GENIII's Avatar
^^^ This. With the NV4500, I needed the high hump. When I had the 400 in it, I could have fit another transmission between the 400 and the tunnel..... well not really but there was a lot more room though. Not so much with the manual trans now.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-31-2019, 08:39 AM   #19
nsb29
nsb29's Avatar
I had to go to a high hump with my LS swap to clear the 6L80 trans
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-31-2019, 08:44 AM   #20
nsb29
nsb29's Avatar
I got a dum question how does dropping the truck Change Transmission clearance is it because you have raised the transmission for ground clearance
Old 12-31-2019, 08:45 AM   #21
nsb29
nsb29's Avatar
Old 01-05-2020, 03:27 PM   #22
lilpoindexter
lilpoindexter's Avatar
I like the low hump look. My 63 3ott had the low hump factory. Even if i have to have a 4L60 instead of a 4L80 or whatever i would do it, since i want the low hump.
lilpoindexter is offline   Reply With Quote
