08-23-2016, 09:06 PM | #1 |
K30 gear ratio
I am building a 86 K30. Seem to have a lot of housings front and rear with 4.56 gears. I was hoping for 4.10s. I am putting a 454HO crate engine in it with a 4L80E with a divorced NP205 or a Divorced Rockwell 221 T Case. What do you all think about running the 4.56 gears in this truck? Not an off road rig for sure. 235/85/16 tires on it. I am thinking about highway rpms.
Member # 286 1975 Trans Am 1986 GMC Wrangler 4X4 1985 Silverado K30 Dually 2016 Skidoo Renegade XRS 800 2016 Yamaha Grizzly 700 |
08-23-2016, 10:08 PM | #2 |
Re: K30 gear ratio
Punch your numbers in here.
http://www.advanced-ev.com/Calculators/TireSize/ About 250 rpm difference at 70 mph between ratios. |
08-24-2016, 01:47 PM | #3 |
Re: K30 gear ratio
4.10 still sounds like a low ratio, expecially with a big block.
I don't know what kind of highway speeds you're looking to run, but I used to have a nice 1972 C10 with 4.10 gears, and a 350/350 combo. My tires were just a little smaller, I think I was running 31 inch tires while you're looking about 32, but I was screaming RPMs at highway speeds. It was geared low because it originally built as a camper-special, but with the camper weight off it became a sports car (to a teenager), it launched off the line. I loved that truck. You've got overdrive, I think that will help with highway RPMs, but that 454 should easily be able to push much taller gearing. What are you looking for from this truck? Heavy towing, max 65mph speeds?
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
08-25-2016, 11:31 PM | #4 |
Re: K30 gear ratio
It will be snappy with the big block, 4L80e and 4.56 gears, but much faster than 65mph and you will wish you had shorter gears. Oh and it will pull a house down. If you're cruising I'd try to find 4.10 or even 3.73. Mine pulled a heavy trailer pretty well with those gears and a tired TBI 350, so if you are going to work it and drive slow, great setup.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
08-26-2016, 01:03 AM | #5 |
Re: K30 gear ratio
I have done this very swap and for sure would not do 3.73. I have 3.73's and when towing or using my slide on camper the additional 10% of running 4.10's would be great. I wouldn't even be opposed to 4.56's . With 3.73's I am about 1700 rpm at 60. Keep in mind the carrier in the Dana's change when going above 4.10. So that may help make your decision as well.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
