Old 08-24-2016, 08:35 AM   #1
Grumpy old man
Grumpy old man's Avatar
recovering armrests / color change
I recovered a set of armrests for 70Stovebolt to get rid of the funky blue reproduction color .
http://
http://
http://
Last picture shows reproduction armrest distortion .
http://
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 08-24-2016, 10:31 AM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: recovering armrests / color change
Grumpy, that looks great!! I think that color match is as close as you can get to the original blue. I think these aftermarket armrests are made of a different kind of foam than the originals, and that is why they distort like that. They are not as easy to install as originals either, but at least now they will match the rest of the interior. I will post some pics when I get them installed.
Thanks,
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-24-2016, 11:52 AM   #3
dfwright
dfwright's Avatar
Great job on the recovering. It looks excellent!
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 08-25-2016, 12:52 PM   #4
San Diego Ron
San Diego Ron's Avatar
Very nice Grumpy, wish you would go into detail on the process of recovering them...I would like to give it a try.
San Diego Ron is offline   Reply With Quote
Old 08-25-2016, 06:51 PM   #5
Grumpy old man
Well... you need a commercial walking foot sewing machine ($1,400.00) , air compressor ($750.00) with a low cost Harbor freight cup gun($15.00) to spray the glue , You need automotive landau top spray grade adhesive (5 gals is $140.00) then the rest is easy cutting the material ($15.00 to $25.00 a yard with shears $55.00 a pair ) on the bias (diagonal ) to get it to be able to stretch over multiple corners and curves . Shape out your pattern (it takes 3 separate shaped pieces) and starting from the center on the back side of the material pieces 1and 2 sew (Thread $14.00+ per spool / color) them together then again from the back center sew the opposite side then from the front sew the decorative french seam .repeat process with pieces 2 and 3 . now with your material sewn make a center mark on the back side of the material and the top of the arm rest which has to be cleaned using lac thinner to remove the gloss sheen from the armrest to allow the contact cement to adhere. Using the spray glue evenly spray the top of the arm rest and the back side of the top of your material panel ,allow 10 minutes for the contact glue to set and then lightly set the center and using a very light touch while stretching align the material to the armrest top (tread lightly because once you apply pressure to the material covered in contact cement it's gonna be stuck !) . Once you have the top panel set in place you then spray a few inches at a time down the face of the armrest and again allow 10 minutes for the glue to set ,using a light touch again while stretching lightly smooth the material to adhere to the armrest surface all along following curves /contours with no wrinkles . repeat process 3 more times to get all the exposed surface of the armrest covered and wrinkle free . repeat process on the back edges again with no visible wrinkles . trim excess material ,staple edges with stainless steel staples(air stapler $125.00 Stainless staples $55.00 a box , You don't want rust coming from behind your armrest ) and your done ... Now do the other side .....
Old 08-25-2016, 07:07 PM   #6
SoCoC10
SoCoC10's Avatar
Originally Posted by Grumpy old man View Post
Well... you need a commercial walking foot sewing machine , air compressor with a low cost Harbor freight cup gun to spray the glue , You need automotive landau top spray grade adhesive (5 gals is $140.00) then the rest is easy cutting the material ($15.00 to $25.00 a yard ) on the bias (diagonal ) to get it to be able to stretch over multiple corners and curves . Shape out your pattern (it takes 3 separate shaped pieces) and starting from the center on the back side of the material pieces 1and 2 sew them together then again from the back center sew the opposite side then from the front sew the decorative french seam .repeat process with pieces 2 and 3 . now with your material sewn make a center mark on the back side of the material and the top of the arm rest . using the spray glue evenly spray the top of the arm rest and the back side of the top of your material panel ,allow 10 minutes for the contact glue to set and then lightly set the center and using a very light touch while stretching align the material to the armrest top . Once you have the top panel set in place you then spray a few inches at a time down the face of the armrest and again allow 10 minutes for the glue to set ,using a light touch again while stretching lightly smooth the material to adhere to the armrest surface all along following curves /contours with no wrinkles . repeat process 3 more times to get all the exposed surface of the armrest covered and wrinkle free . repeat process on the back edges again with no wrinkles . trim excess material ,staple edges with stainless steel staples (you don't want rust coming from behind your armrest ) and your done ... Now do the other side .....
Wow! That's all! I think I'll leave the arm rest recover work to the experts. Grumpy would you be willing to do the 67 style armrests that only come in red and black? I'd like to get a price on changing my black ones to medium blue.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 08-25-2016, 07:37 PM   #7
Grumpy old man
The best way to get them to match is to have them redyed . When done correctly it lasts a long time and to find the right guy to do it hit up the guys in the detail shops at any local large auto dealer and ask who's doing their dye work ? , These auto interior (vinyl repair) detail jobbers are working every large car dealership parking lot in your town working on the trade ins and small warranty repairs and they can custom match any color ,repair small tears or burns in your upholstery and do it everyday for the dealers . I'll bet a donut they'll fix you up for $20.00 cash or a 12 pack of beer (they make good money from the dealers on repairs compared to replacing steering wheels and seat covers .) Everything in my trucks match perfectly but only because I do all my own dye work .
Old 08-25-2016, 08:10 PM   #8
San Diego Ron
I have a Consew walking foot machine and most of other stuff so going to give it a try once I get the big stuff finished (getting truck ready to paint, but you know that because you just told me about windshield gasket). Thank for directions and knowing me probably will be pestering you again once I get started.
Old 08-25-2016, 08:40 PM   #9
70STOVEBOLT
Got the armrests today. Only issue is there are no holes for screws. How should I make holes for the screws?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 08-25-2016, 08:55 PM   #10
Grumpy old man
Holes ? you said you wanted them covered ? you didn't say anything about mounting them !
I forgot to send the pieces ,Loews sells a 1/2 hole plug that I wrapped with the same vinyl that you insert in the hole after mounting them on the door to give them a clean finished look with no HOLES !
Just take a razor and cut a very small slit just big enough for the screw to fit thru the center of the armrest hole NO BIGGER YOU WANT THE PLUG TO COVER ANY HOLE YOU MAKE WHEN INSERTED .
When dealing with any upholstery "if it ain't tight ,it ain't right "
Old 08-25-2016, 09:32 PM   #11
70STOVEBOLT
Sooo..... You have some plugs you're going to send?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 08-25-2016, 09:38 PM   #12
Grumpy old man
Sure ...There $56.90 each !
No I kid you ! I just forgot about them until you mentioned the hole , I'll ship them to you in a padded envelope .
Old 08-26-2016, 08:14 AM   #13
70STOVEBOLT
Thank you sir, I will post some pics of them installed.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 09-01-2016, 01:47 PM   #14
70STOVEBOLT
I hate to be a pest, but I have to ask, did you send the plugs for the armrests?
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 10-12-2016, 08:20 AM   #15
70STOVEBOLT
Still no plugs...
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
