08-25-2016, 12:40 PM | #1 |
Blind rivets
Replacing window regulator and weather striping and seals, have vent window apart to replace rubber but can't find anyone local that sells the rivets so I can get it back together (pop rivets won't work). Have truck about ready to paint but window is holding me up...is there something else I can use or where can rivets be found, not that I know how they are crimped.
08-25-2016, 01:24 PM | #2 |
Its a Truck Thing......
Re: Blind rivets
Ah,
The fun with Tubular rivets. Contact WES at classic heartbeat (888) 338-2502. and here is a good tool to install them, they are a pain..... http://www.zr1netregistry.com/Market...Rivett-II.aspx Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time |
08-25-2016, 01:25 PM | #3 |
Re: Blind rivets
I have no clue where to get the rivets, but in the past if i needed something like that i would take a piece of tubing (brake line) that fit into the hole, then peen both ends. Ain't pretty but it does the job. If you are after pretty, then grind some mandrels and slowly work them down. If possible heat them, or preheat, then shove in hole and peen. Just like building a bridge.
08-25-2016, 01:32 PM | #4 |
Re: Blind rivets
Thanks and finding out the correct name also helps.
08-25-2016, 01:35 PM | #5 |
Re: Blind rivets
My kind of thinking My67c20, like that idea a lot.
08-25-2016, 01:36 PM | #6 |
Re: Blind rivets
No problem.
Smitty
08-25-2016, 08:19 PM | #7 |
Re: Blind rivets
That job is finished...got lucky and was able to use 1/8" pop rivets to hold everything together...was going to remove nail from rivets and smash over the end but they worked as is and ended up being flush. New regulator in, window glass in, vent window in, new window channel in, new whiskers on...yea!
08-30-2016, 03:57 PM | #8 |
Re: Blind rivets
Both doors now finished now I can move on to the paint part.
