Old 10-06-2003, 10:51 AM   #1
sactoC10
71 DELUX
sactoC10's Avatar
valve cover holes 2 - 3 ???
OK,
This may be a simple question to some of you, but being the perfectionist that I am, it is a concern for me. I am cleaning up my engine compartment and will probably get to the point of installing my Mr. Gasket chrome valve covers in the next month or so.
Over the weekend I realized the there are three holes in the stock valve covers 2 on one, 1 on the other and most of the aftermarket chrome ones only have one hole on each.
Is the normal thought here simply to keep the breathers in place and then add oil in one of the breather holes instead of having a separate oil fill hole?
Just need to know. Thanks!
sactoC10 is offline   Reply With Quote
Old 10-06-2003, 11:11 AM   #2
crazy longhorn
Fabricate till you "puke"
Yes, all you need is the 2 holes.....1 for the breather, & 1 for the pcv valve. I just add the oil to 1 of the holes, after popping the pcv out. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-06-2003, 01:27 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
Yup....put the PCV at the driver side front of engine valve cover hole, and put the breather in the passenger side rear of engine valve cover hole. Then your engine will suck air in through one side, and release it back into the intake on the other side.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-06-2003, 04:21 PM   #4
sactoC10
71 DELUX
sactoC10's Avatar
adding oil...
Imagine that adding oil is then done much easier in the more forward hole on the driver's side, no? Better go to my collection of pix to see how this looks on everyone else's rides.
Thanks!
Old 10-06-2003, 04:22 PM   #5
lukecp
lukecp's Avatar
Yup, just yank the PCV valve out and pour the oil in through a funnel. That is what i do on mine......pics on my website, the link is in my signature.
Old 10-06-2003, 04:27 PM   #6
sactoC10
71 DELUX
sactoC10's Avatar
Went to you link, good info, nice little site for your truck.
Old 10-06-2003, 05:59 PM   #7
lukecp
lukecp's Avatar
Old 10-09-2003, 11:42 AM   #8
70 longbed
An old post, but now pertinent to my putting the valve covers back on. What is correct?
My valve covers (orginal) are notched on one side. I took that to mean that side towards the intake manifold. Someone else told me that there is actually a heighth difference in the valve cover from side to side, and was so the rocker arm didn't constantly hit the inside. Yet another person told me that on a 350, I could put them on anyside, anyway, that I wanted. I did not get a good picture of which way they were when I bought it, but not sure that it was correct even then.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 10-09-2003, 11:56 AM   #9
67chevemall
67chevemall's Avatar
2 holes is all ya need! In spring I like to put half the oil in each side to wake up the rockers!
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-09-2003, 03:18 PM   #10
sactoC10
71 DELUX
sactoC10's Avatar
Maybe someone can explain to me why it is then that there are no holes on some vehicles? If the holes are there to allow for/create more breathing...what would be the advantage of not having them?
I am still confused on the whole point of this, even though I now know the two holes will be fine.
Old 10-09-2003, 03:44 PM   #11
67chevemall
possibly for universal applications!
Old 10-09-2003, 03:51 PM   #12
sactoC10
71 DELUX
sactoC10's Avatar
Guess I could have been more specific...
In my collection of photos it seems that I often see 350's without the holes or the breathers installed. So that is my question (and shows my ignorance in the realm of engine buidling). Why do some people choose to run without the breathers?
Old 10-09-2003, 04:05 PM   #13
67chevemall
Thats a great ?!!
How does the motor breath if there is no holes in the valve covers
Never thought of that before. ?
Some one out there has to be running this kind of valve cover!!
Old 10-09-2003, 04:19 PM   #14
crazy longhorn
The old 238s & 327s had no holes in the cover(prior to 1968). These engines had a breather tube in the front of the intake manifold, & the pcv was routed to the rear of the block(next to the distributor). the pcv actually screwed into the rear of the carb, or was in the hose (2 brl or 4 brl).The baffle was under the intake manifold. If you go back a few yrs more, there was no pcv.....just a road draft tube, & a vent ube on top of the intake.(not too good for emissions). CrazyL
Old 10-09-2003, 04:23 PM   #15
67chevemall
Kool!
So the motor has to be vented to work??
Just a matter of where???
