Old 08-26-2016, 09:14 AM   #1
Ewr101
Ewr101's Avatar
Trailing arm Question
I want to remove, clean up and paint the rear trailing arms along with replace the bushings in it and the panhard bar. What's the right way to safely remove them? And do I need to take any precautions beforehand to make sure they go back in correctly and the rear end is aligned properly?
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
Old 08-26-2016, 10:22 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Trailing arm Question
The trick is to not crush the ends of the trailing arms together when putting in the new bushings. You'll want to wedge a spacer in there while you press in the new ones. What I did to help reinforce the arms is to weld a spacer into the end, like boxing it in. Here's a couple pics. Using a press make removing/installing much easier.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-26-2016, 12:07 PM   #3
Ewr101
Ewr101's Avatar
Cool, I'll keep that in mind when I get to that point. But what's the best way to actually get the arms off the truck? Is it just as simple as unbolting everything and then reassembling?
72 Chevy 2WD Blazer
Old 08-26-2016, 03:27 PM   #4
SCOTI
SCOTI's Avatar
Yes. You just need to have some extension when pulling the springs out. Soak everything w/penetrating oil before your scheduled work date to make disassembly go faster.
Remove shocks.
Loosen & remove springs.
Remove rear-end U-bolts.
Remove e-brake cables from the T/A's.
Remove the front T/A mounting bolt.
Remove the T/A.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-26-2016, 04:01 PM   #5
Ewr101
Ewr101's Avatar
By extension, do you mean like a prybar to get the springs out? And something for the body to rest on while its all a part too, say a couple of jack stands and a 4x4 block of wood? Sorry for all the questions, it's my first time to pull off a suspension system off of anything....
72 Chevy 2WD Blazer
Old 08-26-2016, 04:48 PM   #6
SCOTI
SCOTI's Avatar
Jack the rear of the truck high enough & put it on jackstands. You'll want to be able to allow the rear-end room to droop (enough to relieve pressure on the spring).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-26-2016, 06:57 PM   #7
Ewr101
Ewr101's Avatar
I'm gonna need some taller jackstands!
72 Chevy 2WD Blazer
