Old 08-26-2016, 10:11 AM   #1
Bluegrain64
72 GMC driveshaft question/swap
Hello everyone. I just purchased a 72 gmc 1/2 ton LWB 2WD.
It was originally a 350/4bbl automatic.
My questions are:
1.would the original transmission been a 350 or 400?
2.Also, it obviously has a 2 piece shaft but mine has a greasible slip yoke and what looks like a HD center bearing. Is it because I have rear leaf springs?
3. I'm looking at purchasing a brand new assembled driveshaft from a friend. It doesn't have the greasible slip yoke. Would his driveshaft work on mine?
I'm trying to learn more about these trucks.
Thanks.
Bluegrain64 is offline   Reply With Quote
Old 08-26-2016, 01:55 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 72 GMC driveshaft question/swap
The greaseable slip yoke is a much better design. Look under any truck built after 73.... there's a reason for that, leaf springs move the rear end around a lot more than a long control arm setup.
Keep your driveshaft.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-26-2016, 03:18 PM   #3
Bluegrain64
Thank you Sir! That's all I needed to know!
