Old 08-27-2016, 06:06 AM   #1
davem815
davem815's Avatar
Bolts added to exterior of bed
Does anyone know what the (4) carriage bolts in the outside of the bed would be for? They look like they have been there for years.
There are two in each side, in the front two stake pockets. They are carriage bolts, with the head spaced away from the sheet metal by the thickness of the square on the bottom of the head. There is a nut on the inside of the bed pockets, just below the pocket bottom
Some kind of camper mount??? These are on a '66 GMC 3/4 ton longbed.
1966 GMC 1500 (3/4 ton) Custom V6 3sp Edna
1970 GMC C2500 Deluxe lwb 307/4sp Ol' Green
1971 Chevy C20 Custom lwb 307/3OTT, now a project in family since 1974
2014 GMC K2500 Crewcab 6.0 gas
2005 GMC Canyon Ext cab 4wd daily driver
1963 F*rd/Howe C750 fire truck 11,000 miles
davem815 is offline   Reply With Quote
Old 08-27-2016, 09:04 AM   #2
Re: Bolts added to exterior of bed
That would be my guess, but truthfully no clue.
Old 08-27-2016, 10:53 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Back then they has T-like tie downs for our trucks, if they are closer to the cornea I would say that is what they are from but someone removed the t- shaped part and just filled the hole with a bolt
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-27-2016, 06:53 PM   #4
Classic v6 GMC's
Classic v6 GMC's's Avatar
Extra support for the stake pocket?
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 08-27-2016, 09:03 PM   #5
60chevyjim
60chevyjim's Avatar
on my 65 the stake pockets are broke loose and that would fix the problem but I don't like the look of the bolts like that .
60chevyjim is offline   Reply With Quote
Old 08-27-2016, 11:55 PM   #6
Vernski
My 65 GMC had bolt holes from the side of the stake front to back, I think they were to hold the stake securely so the stake don't rattle in the pocket. Mine were drilled into the stake on the inside of the box as I said front to back and all six were drilled. I also don't think it came from the factory this way either.
You can always fill them and in your case or just paint over them. Just depends how much time and money you have, I don't think the smooth end of the carriage bolt looks to bad…Vernski
Vernski is offline   Reply With Quote
Old 09-04-2016, 05:55 AM   #7
davem815
davem815's Avatar
Thanks for the replies.
No knowing why there were installed, I will probably remove them and weld the holes. ( one bed side needs replaced, so I'm half way there either way) i tdon't want to be asked why they are there and not have a good answer. If I knew why they were there, I would be tempted to leave them.
