Old 10-06-2003, 01:57 PM   #1
easy4
Best 2 Inch Lift
I AM IN THE MARKET FOR A 2 INCH LIFT KIT FOR MY 71 2500 4X4
WHO BUILDS THE BEST
71 gmc 2500 4x4 ugly yellow
easy4 is offline   Reply With Quote
Old 10-07-2003, 05:27 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I installed the Tuff Country 2" heavy duty front springs. In the rear I removed the factory 1" block and installed a 2" tapered block and add-a-leaf. The HD springs are that and I probably should have went with the ez ride springs(the difference is an 18" short leaf added to the bottom of the spring pack I would remove but I plan on going to 6"). Pics in sig link.
Go here: http://67-72chevytrucks.com/vboard/s...threadid=71617
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-13-2003, 12:37 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
In 1997 I installed Skyjacker Softride 2.5" springs up front (the oem springs were sagging), and I still like 'em a lot. Running KYB Gasajust shocks. I have Add-a-leafs in back and the front is just slightly higher than the back, so I didn't use the blocks that came with the springs.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-14-2003, 10:36 AM   #4
Bram
Broke
Bram's Avatar
Hey Stocker, how many leafs are on that front 2.5 Skyjacker, 5 leaves ?
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 10-14-2003, 10:47 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup, 5 tapered leaves. Nice ride, too, well matched with the rears. Kit came with poly bushings, 2" tapered rear alum. blocks, and new u-bolts & nuts front & rear. Like I said, I'm happy with 'em!
- Mike -
RIP El Jay
