So which trams do I get 200, 300,350 400?
I currently have a 700r4 heavy hauler in my 69 C10. It shot. I don't need OD. Don't care aBout fuel economy. Don't race. Just want a nice smooth quiet transmission. Car has a 350 crate and 3.78 posi.
Posted via Mobile Device |
![]() Join Date: Mar 2003
Re: So which trams do I get 200, 300,350 400?
Just have that one rebuilt and don't worry about having the drive shaft redone. OR find a T350 have it rebuilt and installed and lengthen the drive shaft
I like the turbo 350. easy & simple to run
th350s will be cheapest.
350 is good i can attest to that, though I do wish I had OD. I can barely go past 60 MPH, 55 if I do not want to make it scream the whole way. What sucks is the speed limit on the highwas around here are 70 MPH (roughly, 120 KPH)
then again IDK what i have for sure, the Vin/SPID indicates it is a turbo 350, but it has already had a 305 transplanted, not sure about the tranny. Need to investigate that! |
Easiest is just to have that one rebuilt. By the time you change it all out foe a non o/d, the little bit you save on the trans will be offset by the cost of changing the driveline.
You will miss the o/d with those gears too.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#7 | |
![]() Join Date: Nov 2004
![]() If (when) gas gets back to $4-5/gal in Cali, you'll wish you had that extra 2-3mpg. Around here a bench rebuild is only aournd $7-800. A R&R is around $12-1300. Also, why did it burn up? Crap load of miles? Hard driving? Just old? 700R's are sensitive to proper TV cable set up. You can set one up with a simple pressure gauge screwed into the 4th gear port and setting it within the proper PSI range for shifting (it's floating around here somewhere.) Good post on procedure: http://67-72chevytrucks.com/vboard/s...d.php?t=526152 Pics of where to hook it up: http://www.tvmadeez.com/press_gauge/pressgauge.html
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-29-2016 at 09:01 AM. |
![]() Join Date: Aug 2015
I concur with getting the 700 rebuilt, it is a good tranny. If you switch to the 200-4R, TH350, or TH400 I think the drive shaft will have to be replaced. Out of them all I prefer the 200-4R because of the OD, and it used less HP to operate than the 700-4R. I know nothing of the 300.
http://www.oldengine.org/unfaq/leadfoot/trans.htm Kevin |
