Old 08-27-2016, 09:46 PM   #1
Vero67
67 K10 manual steering box problem
I was looking at the manual box on my truck. Turning the steering shaft back and forth, I can see steering box flex where the shaft comes out for the pitman arm. The rest of the box appears solid. I recently noticed a vibration around 45mph and wonder if that is my problem. Any suggestions where I can get a replacement without getting raped? Thanks John
Vero67 is offline   Reply With Quote
Old 08-28-2016, 08:01 AM   #2
Vero67
Re: 67 K10 manual steering box problem
All the information I find list the manual steering box as 67-68 only. Will a 69 and up manual box fit? I have a straight six and am not looking to convert to power steering.
Old 08-28-2016, 08:35 AM   #3
Bigdav160
Bigdav160's Avatar
Those manual boxes will wear the bearings especially if the gear box oil/grease hasn't been changed. They are not difficult to overhaul.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-28-2016, 07:25 PM   #4
Vero67
Is there somewhere I can buy a rebuild kit.
Old 08-28-2016, 09:25 PM   #5
jmader
jmader's Avatar
I couldn't find a rebuild kit for mine so I ended up sending it to RedHead to be rebuilt. If I remember right it was around $200.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 08-29-2016, 02:45 PM   #6
Vero67
It's my daily driver so I can't really be without it for a couple of weeks.couple
Old 08-30-2016, 01:20 PM   #7
Vero67
I ordered a rebuild kit from Benchworksteering.com. Kit was $69.95. It is for manual boxes ending in 42 or 80. They were the only ones online that I found. Hope this helps someone else.
Old 08-30-2016, 03:02 PM   #8
Bigdav160
Bigdav160's Avatar
In the early 1990's I was working at a GMC dealer. The bearings broke in my '72 Corvette steering box on the way to work.
Surprisingly, they had the bearings in stock and I drove the car home at the end of the day.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 08-30-2016, 06:26 PM   #9
michael bustamante
michael bustamante's Avatar
is the 4wd and the 2wd different manual boxes? i have a 2wd manual out of my 67 i wont need
1967custom
michael bustamante is offline   Reply With Quote
Old 08-31-2016, 11:59 AM   #10
Vero67
I believe the 4wd mounts on the outside and the 2wd mounts on the inside. 4wd is the push pull set up.
