08-27-2016, 11:57 PM | #1 |
Rochester quad?
What's #1 in this image called? I believe this is the felt gasket that sits between the carb and air cleaner. Also, does anyone know a great source for identifying carburetor parts, including the automatic choke? My 71 was replaced by a manual choke, but I'd like to restore it. The 72 has a automatic choke but may not be complete or working. Pics of a complete choke on a truck would be great. I'm assuming the choke system is the same, big or small block. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-28-2016, 09:33 AM | #2 |
Re: Rochester quad?
The correct carb for 71-72 is a 4mv quadrajet, 7041218 I think is the proper number. It was a auto choke controlled by a bimetallic spring on manifold, not electric. The electric choke came later 76-78 range. The carbs are a little different big block and small, it is based in the lower base plate. The small block carb should have kick down arm while big block will not have the arm.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
08-28-2016, 09:47 AM | #3 |
Re: Rochester quad?
Try here. Some good pics or diagrams for your choke.
http://www.carburetor-blog.com/free-...epair-manuals/ |
08-28-2016, 11:50 AM | #4 | |
Re: Rochester quad?
1971: 7041209 1972: 7042206 Thank you for the response.
08-28-2016, 12:07 PM | #5 | |
Re: Rochester quad?
Found this pic of a 402 with choke, in case anyone else is interested:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-28-2016 at 12:12 PM. |
08-28-2016, 12:21 PM | #6 | |
The Older Generation
Re: Rochester quad?
The spring fits inside of the metal housing on the intake. There are a few listed on e-Bay. Everyone lists them as Corvette springs, I guess they think they will get more for them that way.... http://www.ebay.com/sch/i.html?_from...pring&_sacat=0 I think you adjust them by bending the rod that connects them to the choke lever. LockDoc
08-28-2016, 12:41 PM | #7 |
Re: Rochester quad?
Air horn gasket
08-28-2016, 01:23 PM | #8 |
Re: Rochester quad?
You can buy the replacement spring at a parts store. I just replaced mine about 3 years ago and remember it being pretty cheap.
Posted via Mobile Device |
08-28-2016, 01:59 PM | #9 |
Re: Rochester quad?
At first glance I thought so too, but I'm not so sure: http://quadrajetparts.com/quadrajet-...128_25_39.html
Correct me if I'm wrong, but it looks like the spring mounts to the manifold using one screw. There are two holes in the manifold. One may be for a pin on the bottom of the housing cover.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-28-2016 at 02:08 PM. |
