I am a Referee of life.
McGaughys brake pads.
I've had a set of McGaughys aftermarket brakes for about 10 years. One of the calipers wasn't working well so I was going to bleed the brakes. The caliper was bad so I ordered a new one from the local Advance and got a new set of wearever Gold pads. No go. The loaded calipers only give 1 1/8 in of clearance but the rotor is 1 1/4 thick. Anyone have a part number? The caliper crossed (by the casting number as a 71. I'm assuming the rotor is a HD unit but when I was at the LAPS, I got a Millennial in the body of a 60 YO, so no help there. 20 min to explain what I was looking to repair and he still didn't have a clue.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: McGaughys brake pads.
did you try a cclamp to have the caliper over the rotor
Fully collapsed the piston into the caliper. Still need an 1/8. The parts guy did suggest I machine it off the rotor which has never worn enough to need machining( it's probably got 5000 miles at most and new pads are all that's ever run on it.
