08-28-2016, 05:36 PM | #1 |
How t refill rear axle?
I'm changing to fluid in my rear axle, but there is no fill plug, that I can find.anyway. Do I just put it in through the vent tube connector? Or is there a threaded plug somewhere on the housing?
08-28-2016, 05:45 PM | #2 |
Re: How t refill rear axle?
If it's a 12 bolt it's around the passenger side on the front. It has a square hole and you insert a 3/8 inch socket extension into it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-28-2016, 05:45 PM | #3 |
The fill is on the passengers side on the front of the case by the drive shaft .fill it until it runs out .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-28-2016, 06:03 PM | #4 |
Yep, thanks to both of you. I went out and crawled around it again an found it. I'll be back on the road again soon
08-28-2016, 08:02 PM | #5 |
Done. Thanks for yalls help.
Changed out two gaskets today ( trans and rear diff) and neither one leaks. Good day |
