08-29-2016, 04:51 PM | #1 |
automatic braking... wait... my truck is not autonomous!
On my way home from West Coast Natls yesterday doing about 70 when the truck started jumping/bouncing slightly, became much worse by the time I was able to get over two lanes and off to the side. Did a quick look around and found nothing so I thought I'd drive up to the next exit for a better look, although my truck thought otherwise, brake pedal was very stiff and my engine was fighting the brakes. Remembering some issues(more below) from last week, I shut off the engine and then brought her back up which released the brakes and everything was back to normal.
Back up to last week, I noticed a leak from the cap of my reservoir and the rubber seal had been partially sucked in. Cleaned, reseated and closed. After driving the next day, the same thing although a much worse leak (no more por-15 on the frame below). Cleaned everything up, searched, read a bunch regarding the problem, and followed a few peoples idea of making and installing a cork gasket just below the lid. Held up with no leaks, even after the self-applying incident on the way home yesterday. Not sure what to do at this point, may flush the whole system. BTW, this is a hydroboost setup. Any ideas are appreciated.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
08-29-2016, 04:59 PM | #2 |
Re: automatic braking... wait... my truck is not autonomous!
Self-applied brakes can be caused by a MC that is too full, or a clogged vent in the MC.
08-29-2016, 05:30 PM | #3 | |
08-29-2016, 06:25 PM | #4 |
The Older Generation
I would make sure that the brake pedal is coming back all the way and there are no brake lines routed near any of the exhaust. LockDoc
08-29-2016, 07:11 PM | #5 | |
haha Leon, randomly throughout the day I've been thinking of you mentioning the heat issue in one of the threads about leaking caps at the reservoir. Going to check into that in a bit.
