Old 08-29-2016, 05:57 PM   #1
tjsblazer
tjsblazer's Avatar
Arrow WTB: Parking Brake Cable Spring ('72 4x4)
I'm looking for the Parking Brake spring that connects between the end of the front cable adjustment rod and the body cross-member. Mine is from a '72 4x4 Blazer but I'm pretty sure it is the same on a K10. Link below to my WTB thread with pictures in the Blazer section.
http://67-72chevytrucks.com/vboard/s...d.php?t=716366
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 08-29-2016, 07:52 PM   #2
JimKshortstep4x4
Re: WTB: Parking Brake Cable Spring ('72 4x4)
Our local Ace Hardware has an extension spring selection and they carry a spring that is pretty close to what you need.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-30-2016, 08:32 PM   #3
tjsblazer
tjsblazer's Avatar
Thanks Jim, I may end up having to go that route. Right now I don't have anything to go off of so I'd like to find one from a part out or even if in rough shape I can use it as a guide for a close hardware replacement.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-03-2016, 12:34 PM   #4
tjsblazer
tjsblazer's Avatar
Still looking
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-06-2016, 05:20 PM   #5
tjsblazer
tjsblazer's Avatar
post labour day bump
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-23-2016, 10:47 PM   #6
tjsblazer
tjsblazer's Avatar
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-24-2016, 10:05 AM   #7
John H.
John H.'s Avatar
Jeff,
I have one I could send you for shipping price.
I will get a picture when I am back Sunday evening.
John
John H. is offline   Reply With Quote
Old 09-24-2016, 11:57 AM   #8
tjsblazer
tjsblazer's Avatar
John. That would be great.
Thanks, Jeff.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-25-2016, 11:54 PM   #9
John H.
John H.'s Avatar
Here you go. Not perfect but may work for you.
Old 09-25-2016, 11:55 PM   #10
John H.
John H.'s Avatar
Came of 72 LWB
Old 09-25-2016, 11:56 PM   #11
John H.
John H.'s Avatar
Old 09-26-2016, 05:14 PM   #12
tjsblazer
tjsblazer's Avatar
John. I really appreciate your effort on this but the one off my Blazer is only about 7" overall length so that one won't work.
Again thanks for trying.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-26-2016, 08:00 PM   #13
JimKshortstep4x4
We have several 4x4's and one Blazer and the springs are the same approximate length as the 7" length you mentioned. I will check with my local hardware to see if they have one that will work for you.
Jim
Old 09-26-2016, 08:26 PM   #14
tjsblazer
tjsblazer's Avatar
Around me I haven't had any luck. I found one close at 6.5 but the gauge of wire was much thicker and much higher pull force.
If you see something I'd be interested in knowing.
Thanks. I did find one online but minimum order was 100 pieces!!
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-28-2016, 05:21 PM   #15
JimKshortstep4x4
I measured the one stock extension spring that is on one of my trucks and the approximate measurements are as follows:
Length 7"
Diameter 1/2"
Wire diameter .o67
Ends 1 1/2", (both)
Wound coil length, 5"
I have not been able to check out the springs at the hardware but will so soon as I found that I need one, also!
Jim
Old 09-28-2016, 08:24 PM   #16
bluek5
bluek5's Avatar
Jeff,
If you can't come up with anything, I think I have one. Let me know, and I will look for if.
Paul
bluek5 is offline   Reply With Quote
Old 09-29-2016, 10:38 PM   #17
tjsblazer
tjsblazer's Avatar
Paul. Yes I'm still needing. Please take a look and let me know.
Thanks.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-30-2016, 07:05 PM   #18
JimKshortstep4x4
No luck on springs at the hardware store.
Jim
Old 10-01-2016, 01:15 PM   #19
tjsblazer
tjsblazer's Avatar
Thanks for looking. Maybe Paul will find the one he mentioned.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 10-01-2016, 05:31 PM   #20
bluek5
bluek5's Avatar
Thanks.
Jeff,
After looking around and pulling the same spring off of my 4 Blazers, I think I can say without a doubt this is the correct spring.
Paul
Old 10-01-2016, 05:44 PM   #21
tjsblazer
tjsblazer's Avatar
Wow. Thats where they all are.
PM me what you want for one and Ill get you payment sent. In fact I'd go for two if you want to get rid of more.
Thanks. Jeff.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 10-01-2016, 05:58 PM   #22
bluek5
bluek5's Avatar
Thanks. Jeff.
Jeff,
Just PM me a shipping address and I will send you one, assuming you have a US address for shipping. Just put me in line if your Blazer ever needs a new home.
Paul
Old 10-02-2016, 05:03 PM   #23
tjsblazer
tjsblazer's Avatar
Paul PM sent. Thank you very much.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
