Old 08-29-2016, 11:57 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
steering column help
ok just to start off if i didnt have this forum to go to i wouldnt get anything done. so thanx everyone So i have a 71 K10 the steering column is moving in and out. ok so im talking about the inside shaft the one that goes from the steering wheel down to the steering box. now i do have a flaming river colapsable shaft because this truck has a body lift from the PO, but still lets say it did have the stock rag joint in , you can grab the steering wheel and pull it back anf forth about 1/2 inch ....any ideas??
ooimpalaoo is offline   Reply With Quote
Old 08-30-2016, 12:15 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: steering column help
If it was stock I would say that you were missing the large washer and coil spring that hold the lower shaft bearing in place.
LockDoc
Leon
Old 08-30-2016, 12:46 AM   #3
ooimpalaoo
ooimpalaoo's Avatar
ohhhhhh yes i see so i dont know why i cant do that now. i have a u joint on the top instead of the stock (bell) type slip joint. thanx for that i would have never remembered that washer and spring.
Old 08-30-2016, 12:49 AM   #4
LockDoc
LockDoc's Avatar
No problem. I'm not familiar with the column you have but let us know if you can add the washer and spring. It might help others with the same problem...
LockDoc
Leon
Old 08-31-2016, 11:36 PM   #5
ooimpalaoo
ooimpalaoo's Avatar
ok so just as you said and the pic you posted shows the large washer and spring are what hold the bearing from falling out of the steering shaft. now im sure you can do this a few ways. so like i said befor i have a 71 K10 the last ouner installed a 3" body lift. i installed a flaming river shaft and u joints. no more rag joint. and just like the pic you just posted i took the spring from my parts truck and my problem was fixed. thanx again to this site
Old 08-31-2016, 11:41 PM   #6
LockDoc
LockDoc's Avatar
Good deal. Thanks for the follow up!
LockDoc
Leon
