Old 10-06-2003, 06:32 PM   #1
phantom dually
Project92 SWB stepside
phantom dually's Avatar
setting up four link??
I am welding my rear triangulated 4 link brackets on this week. Does anyone have a clue on how to start setting this up? Also where do i measure from to find center in the frame for the rearend. Is the rear centered from side to side on these trucks or were they offset to one side?? Thanks (1983 c10 1/2 ton)
phantom dually is offline   Reply With Quote
Old 10-06-2003, 07:18 PM   #2
fastbagged68
fastbagged68's Avatar
I think all chevy's sit of to one side, I forget how much. You will want to split the difference between the frame rails to the backing plates. Before you weld up anything make sure it works right and double and triple check all your measurements. Think it out and you will do fine. You have made it this far! Keep up the good work!
fastbagged68 is offline   Reply With Quote
Old 10-06-2003, 07:20 PM   #3
fastbagged68
How come you didn't run a par. 4 link? I prefer doing a par. when I can. Less chance of it binding up.
Old 10-06-2003, 07:52 PM   #4
crazy longhorn
Fabricate till you "puke"
the pinoin on the 12 bolt is offset to the passenger side......I dont remember the exact figure either. When I set my longhorn up, I used a straightedge off the axle shaft faces to center the housing in the frame. I am setting up ladder bars, so i cant say on the top tri bars. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-06-2003, 08:12 PM   #5
phantom dually
I already have the top tri bars mounted as they go to a fabricated plate that mounts on the housing of the axle. I am really just wondering about the rear being center side to side and front to rear.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
Old 10-06-2003, 08:17 PM   #6
phantom dually
Fastbagged I ran a tri set up as at the time I was told that it was a good thing to use. Also my tri bar setup differs a little from what others here I have seen that did not like it to well. My bars run from the sides of the frame to the center of the rearend. Also my lower bars run from the stock leaf mounts to the axle. It should work fine I hope!! They are also short less than 24" long and should not sway side to side.
Old 10-06-2003, 08:39 PM   #7
RSG
tri 4 link
Hey man, I just installed a tri 4 link on a 55 chev 1/2 ton. Yes the lower bars need to be centered side to side and front to rear. Also remember that you need to have the lower bars and the upper bars level with each other or you could get some suspension bind. Good luck.
RSG is offline   Reply With Quote
Old 10-06-2003, 09:23 PM   #8
phantom dually
Got any pics??
Old 10-07-2003, 09:21 AM   #9
RSG
sorry dude, no pics yet, hope to have some soon. Will post some when I get 'em (if I can figure out how).
Old 10-10-2003, 09:56 PM   #10
wdz28ss
wdz28ss's Avatar
phantom...check out krzcustoms.com they have a 69 gmc w/ a triangulated 4 link that was in a few magazine articles a bit back and there's a few "building" pics there on it. might give you a few good ideas...I tried to attach their pics, but they are too big.
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had"
wdz28ss is offline   Reply With Quote
Old 10-11-2003, 10:39 AM   #11
Izzy
Trucker.
Izzy's Avatar
Yeah that's a very clean rig it was in Street Trucks about 5 months ago.
http://www.krzcustoms.com/pages/69_chevy.htm
Also that link setup has a "wishbone" upper axle locator so it's not a true tri link but it works just as well.
Izzy is offline   Reply With Quote
Old 10-11-2003, 11:18 AM   #12
phantom dually
That is a pretty sweet frame!!
Old 10-11-2003, 11:19 AM   #13
wdz28ss
wdz28ss's Avatar
what are your plans on your frame phantom? do you have any pics of progress on it yet?
Old 10-13-2003, 05:50 PM   #14
phantom dually
I have the front crossmember notch and lower skid plate raised up also. Running turners upper and lower a arms as well as airbags. Running a mustang 2 rack and pinion (manual). In the rear I have a tri angulated 4 link and a frame notch. The frame is curently powdercoated but will be redone (jumped ahead of myself).
Old 10-13-2003, 09:49 PM   #15
wdz28ss
wdz28ss's Avatar
Phantom....no kidding? I've been talking to you on the crossmember drop thread...I was refering to your plans on the 4-link and back portion of your frame. I know whats going on up front... I'm just looking into building up a back half for mine w/ a tri-4l-link, and was, and am looking for ideas and pictures
Old 10-13-2003, 10:04 PM   #16
phantom dually
***************** has some real good prices on link kits for the do it yourself kinda guy.
