Old 08-30-2016, 09:47 AM   #1
bigmac73
bigmac73's Avatar
brake conversion reviews
http://www.autocityclassic.com/chevy...-rearc105ltrk/
anybody used this set up ?? Looking for reviews before I pull the trigger, seems a little too cheap to be good???
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-30-2016, 10:28 AM   #2
leftybass209
leftybass209's Avatar
Re: brake conversion reviews
Call and ask where they sourced the parts from. $399 is a bit cheap, but most quality rear disc kits have a base price around $500+. Maybe that's a parts store piece-together special.
leftybass209 is offline   Reply With Quote
Old 08-30-2016, 11:11 AM   #3
wbc409
A lot of guys on the 348-409 chevy forum use his stuff. He has designed a few custom brackets that allows you to use standard auto store replacement parts. Which isn't necessarily a bad thing if you plan on driving a lot, or doing road trips with your truck.
wbc409 is offline   Reply With Quote
