Old 08-30-2016, 01:08 PM   #1
eighteenninetytwo
A/C removal.
Hi everybody. Because I am going to run my '75 K5 as a soft top (I got the last white 'softtopper' that they made before they stopped with that color) I decided to eliminate the A/C unit to help clean up the engine compartment (see picture) I have a replacement heater unit from 'A/C delete', but I'm sure there is other A/C related stuff hanging around the place.
What is it and where is it? I see there is a condenser tube unit around the radiator. What else would I be missing?
eighteenninetytwo is offline   Reply With Quote
Old 08-31-2016, 08:31 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: A/C removal.
Once you get the condenser off the front side of the core support, compressor and associated brackets off the motor, and evaporator/drier off the firewall, you've got the bulk of it. There's a different blower motor, fan, and blower motor resistor listed for non-ac trucks and you'll want to change the controls to non-ac. You'll have the wires to the compressor and drier that will need to be dealt with. I'm sure I'm overlooking something.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-31-2016, 10:51 AM   #3
eighteenninetytwo
Re: A/C removal.
The A/CDelete kit comes with new blower motor and fan and we're going to re-wire the whole truck anyway while everything is off / out of it. New wiring harness en route as I type.
