Old 08-30-2016, 02:02 PM   #1
coyn
Factory correct fan
Can someone help me with the factory correct fan setup for a 66 with a 283 in it? How many blades? What does it look like? How big is the spacer? My truck is missing it completely. What about the shroud?
coyn is offline   Reply With Quote
Old 08-30-2016, 08:27 PM   #2
duallyjams
duallyjams's Avatar
Re: Factory correct fan
I assume its a chevy and not a GMC. You can buy a after market replacement fan shroud as far as the fan goes you will have to measure the opening in the shroud as GM used a bunch of different size fan blades and for the spacer will depend on whether you have short water pump or a long water pump.Name:  IMG_2255.JPG
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-30-2016, 10:07 PM   #3
phraza
phraza's Avatar
Originally Posted by duallyjams View Post
I assume its a chevy and not a GMC. You can buy a after market replacement fan shroud as far as the fan goes you will have to measure the opening in the shroud as GM used a bunch of different size fan blades and for the spacer will depend on whether you have short water pump or a long water pump.Attachment 1566173
Where would one buy a shroud like that? Summit etc?
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline   Reply With Quote
Old 08-30-2016, 10:42 PM   #4
DPowers
DPowers's Avatar
This help any? '66 with 283 and short water pump
DPowers is offline   Reply With Quote
Old 08-30-2016, 10:42 PM   #5
cv65
cv65's Avatar
like this one http://www.truckandcarshop.com/trucks60_72/t60_096.html
cv65 is offline   Reply With Quote
Old 08-30-2016, 10:50 PM   #6
phraza
phraza's Avatar
Originally Posted by cv65 View Post
Thanks!!
350 V8
Build thread here
Old 08-30-2016, 11:21 PM   #7
Captainfab
60-66 Nut
The pics DPowers posted show the correct original fan and shroud.
All trucks '72 and earlier originally came with short water pumps.
Old 08-30-2016, 11:57 PM   #8
LT1 Burb
LT1 Burb's Avatar
Factory fan on an original motor I pulled.
LT1 Burb is offline   Reply With Quote
Old 08-31-2016, 03:42 AM   #9
dracko
dracko's Avatar
What year is that engine? Did they have 4 or 5 blade fans from 64-66? Also sidenote, is that a 4 barrel oil bath?
dracko is offline   Reply With Quote
Old 08-31-2016, 06:59 AM   #10
coyn
Thanks. That helps a lot.
Old 08-31-2016, 08:29 AM   #11
jbgroby
jbgroby's Avatar
I know on my 305 V-6 engines, the early models came with a smallish 4 blade fan. When I upgraded to P/S I went on the hunt for a 2 or 3 groove pulley setup and that came with a 6 bladed fan which is strange as the position of the blades not spaced evenly, but it is balanced.
TRY that with a ceiling fan........
jbgroby is offline   Reply With Quote
Old 08-31-2016, 09:10 AM   #12
LT1 Burb
LT1 Burb's Avatar
It is a 65 283 powerglide motor, code WE, that is a 2 barrel oil bath air cleaner, do you need one. I believe it maybe the HD fan with the big radiator and shroud if ordered.
Old 08-31-2016, 02:23 PM   #13
Brad54
Brad54's Avatar
Fans with more than four blades are usually (I won't say "always," because someone will find one) unevenly spaced like that. It keeps the air from "cavitating." With them unevenly spaced, it always gets a "bite" of air.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 08-31-2016, 03:57 PM   #14
bpmcgee
bpmcgee's Avatar
The factory correct fan for a '66 with a 283 is a 4 x 17 5/8"
bpmcgee is offline   Reply With Quote
Old 08-31-2016, 04:03 PM   #15
dracko
dracko's Avatar
Thanks for the info LT1, Brad and McGee... I always wondered why the fan blades were uneven. LT1, thanks anyways but I'm considering running an oil bath on my quadrajet if I can find one for a 4 barrel
Old 08-31-2016, 07:20 PM   #16
duallyjams
duallyjams's Avatar
You can a repro shroud from supporting members on the forum.
James
IG duallyjams
Old 08-31-2016, 08:19 PM   #17
dracko
dracko's Avatar
Someone on the board sells repro v8 shrouds? I am looking to buy one.
Old 08-31-2016, 09:35 PM   #18
LT1 Burb
LT1 Burb's Avatar
Except if you ordered the factory air option or HD radiator and it was this 5 blade fan, also you could have ordered a clutch fan in 65-66 also.
Old 08-31-2016, 10:23 PM   #19
dracko
dracko's Avatar
Good to know, more cooling the better. Were the clutch fans a commonly used part on Chevy vehicles in that era? Or specific to the c10's?
Old 08-31-2016, 11:34 PM   #20
LT1 Burb
LT1 Burb's Avatar
They were very uncommon on C10's and are hard to find, the clutch is unique to the trucks.
Old 06-12-2017, 07:07 PM   #21
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I noticed on my 62 Shroud that a 19" could easily fit, but on my 65 Shroud, it looks like a maximum of 18".
66 C20 Service Truck:
Old 06-12-2017, 07:42 PM   #22
stsalvage
Scrapper 1
stsalvage's Avatar
Thats why when i was doing so much junking from 1993 until 2009.When i ran a pond fans with fan clutch.Ford dodge chevy anything i saved it.It was a pet peeve of mine so was exhaust manifolds for big block and small black car's and trucks.Most people go to electric fans.I rather have the 16-17 inch fans.You know thew Caddys Had the fan clutch but used the 15 inch fan for some of there car's.So i know what you mean I have a Ford 7 blade fan on my 1965 3/4 ton 350 / auto Power glide
stsalvage is offline   Reply With Quote
