Starter help
I finally went to hook my battery back up today after pulling my starter and installing a heat shield a few months back. When I went to hook up the post I got a big spark and the starter clicked. I suspect that this is a wiring issue?
Pulling the starter was a pain with the headers on so I made sure to take pictures and triple check the wiring. There was a rusty old battery post underneath the existing wiring so I removed that while I had it off. So it should actually work better than before. Since I am almost certain it is hooked up right could this be something as simple as a wire touching something it shouldn't be? I tried to ziptie the wires and keep them off of the shield and headers when I put it back on. Please help, thanks. P.S. it worked fine before I pulled the starter. |
Re: Starter help
For it to have sparked like that something must be touching a wire.
Re: Starter help
Re: Starter help
Re: Starter help
This is the way it is hooked up. This picture is before I installed the heat shield. You can see the rusty battery terminal underneath all of it. I removed that and installed heat shield and zip tied the wires. Can't see a damn thing with the heat shield installed.
So rubber coated wires should not touch any metal at all correct? ![]() |
Re: Starter help
No the wires shouldn't touch metal. That blue wire is looking bare and touching the header. At least from how it looks.
Re: Starter help
Trace your wiring, here's a diagram. Looks like too many wires.
https://goo.gl/photos/Ue3KkCYgCXFyUoBM8 |
Re: Starter help
Should be right for HEI. Worked this way before.
Re: Starter help
Found an older picture. Starter is wired wrong..
Re: Starter help
Re: Starter help
also check the large red pos. battery cable going to the starter post. the metal shield in the photo looks as though its touching the threaded stud that holds the starter together. if not touching, it sure looks close.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Re: Starter help
How it is supposed to look.
#13 |
Re: Starter help
I guess I had it right in the first picture. I think you are onto something with the shield arcing.]
#14 | |
Re: Starter help
Thanks for the help. It turns over so that is a start. |
