![]() Join Date: Jul 2008
1967 suburban wheel question transport wheels
Just got done bolting on the 22 inch transport wheels and the passengers side is rubbing a little but but the wheels sit way in.. has anyone ever ran into this and if so what size spacers did you run? And what kind? any help will be appreciated !!! will post pics tomorrow.
1970 chevelle 1971 blazer 1972 c20 custom camper 1931 ford A coupe. |
![]() Join Date: Jul 2015
Re: 1967 suburban wheel question transport wheels
what's it rubbing on? Is the wheel rubbing or the tire?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
both... its tight up against the inner wheel well on the passengers side... now I know the rear end moves from side to side because of the track bar. jsut looking for opinions. thanks!!!
pic
C10 Collector
The 6 lug rear axles are too narrow for the transports and the front hub is too big for the wheel to sit flush. I think I put 3/8" or 1/2" spacer up front with longer studs and on the rear ran a 1.25 or 1.5" spacer. But I broke the spacer studs and ended up reversing the rear wheels so its got a nice dish now and no spacer. Running a 285/35 rear tire and 265/35 front gives it a nice look.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
#6 | |
thanks for info!!! we machined the center hub so the front sits on good now... as far as "reversing" the back wheel... you mean you cut the center out and flipped it??? or?????
ty
C10 Collector
Yes I removed the center, flipped it, Trued it and welded it back up.
I have done some ****.... But i think thats above my pay grade. lol
anyone else?
.... pics
So you bought that truck. That looked like a REALLY nice truck. I missed buying it from the seller in CA by just a few days.
What are your plans for it? Let me know if you ever change you mind and want to sell it. Nick |
#13 |
yes sir... have a few of them , ls swap with a 6 liter and a 4l80 test fiting everything tonight... unless you want to make me an offer before i start on it this weekend. =) lol
#14 | |
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
