Junior Member
![]() Join Date: Jan 2014
Rear End Rebuild
Hey everyone!
I am getting ready to rebuild the rear end on my 69 C10 LWB. Here are the parts that I have on the list to get: Eaton Detroit TruTrac: https://www.summitracing.com/parts/dtl-913a315 3.73 Gears: https://www.summitracing.com/parts/cmb-14-0058 Moser 5-Lug Conversion Axles: https://www.azproperformance.com/Mos...A3065GMT5.html Moser Aluminum Cover: https://www.azproperformance.com/Mos...ruck-7111.html What else I am I forgetting? Thanks for the help! |
Its a Truck Thing......
Re: Rear End Rebuild
Links are having issues for me, but do you have the axle end bearings and seals?
Have you ever done this before? Got the special tools? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
![]() Join Date: Nov 2007
New bearings, pinion depth tool, and if you have a crush sleeve, a 2 ton gorilla.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
I'm in the process of a similar rebuild. I was planning on 2 quarts of rear lube. I'm not to that stage yet, however, so I can't verify. It looks like that kit only includes 1 quart?
It's worth buying an extra set of pinion bearings to use as setup bearings (inner definitely, and probably outer as well). Use a die grinder to enlarge the inner bore so they easily come on/off the pinion. When you get the shims the way you like it, then you can install the final bearings. You'll want a 0-1" micrometer for measuring shims and a dial indicator/magnetic base setup to measure gear backlash. Last edited by bsampson; 08-31-2016 at 03:36 PM. Reason: Addition point |
