63 GMC v6 in a 63 C10?
Found a sweet deal. Someone wants to sell a 305 V6 and can deliver
http://sandiego.craigslist.org/nsd/pts/5758252237.html Have a couple questions for the GMC V6 gurus.... Is it possible to install this motor into my 63 Chevy c10? And link it up to a 3 on the tree tranny? I'm assuming that I'll need to change the motor mounts, where can I find the right ones? And radiator? I currently have a 67 250 I6 with a I6 aluminum champion radiator. And is there anything else I would need to know? I think the alternators are on the passenger side of the motor, so I'm gonna have to figure out how to re wire the charging system? And this motor was pulled from a 63 dump truck, the guy told me that it ran great before he pulled it out, but it scary to drop it in mine without knowing if it needs a immediate rebuild or can last for another few years. Thanks guys! Posted via Mobile Device |
Re: 63 GMC v6 in a 63 C10?
I'm going to ask the guy for a compression test... What are the numbers I should look for?
Post Whore
![]() Join Date: Mar 2013
Alright, so let's start with the Motor.
You'll want to look for 125 PSI in all 6 cylinders and now less than 105 in any of them. Also want to turn the engine by hand to make sure it spins freely and has no stiff spots. Pull the valve covers and make sure all rocker arms are moving as they should. Doing a light rebuild on these is pretty cheap, but the parts are getting a tad hard to find. That price is a steal if the engine is good. Now, Your perches might work, but they will need to be moved no doubt. New motor mounts can be purchased that are single stud instead of double like stock and under $10. That engine may have the larger truck bell housing so you'll want to look into that. Also take a gander at the numbers on the top of the block in front of the passenger side head, that may be a 351C, or E. Will bolt up to the 3 speed with a light duty bell housing. Another thing to remember, These engines used a special clutch disc and pressure plate. The disc is NOT available. But a kit is available that has a disc that is close, but will need some modding which can be done easily enough but is just annoying. You will also need a different thermostat housing, rad hoses, and you'll have to move the regulator to the passenger side. Other than the fact is weighs 800 pounds and is a bear to move around...you should be good. Keep in mind also...the flywheel and clutch assy have to come off before the bell housing will. That's the stupid pos design flaw in these engines.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw Last edited by TJ's Chevy; 08-31-2016 at 10:40 AM. |
TJ please EXPLAIN "Another thing to remember, These engines used a special clutch disc and pressure plate. The disc is NOT available."
#5 | |
Post Whore
https://www.youtube.com/watch?v=-D7fyFKNs4g
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#6 | |
Tj thank you so much! I really appreciate it! I am going to remember all of this, and the guy sent me pictures, I has everything! And I am going to assume that the motor has the larger bell housing because he said it was a 4000 model truck, it might just end up passing because I found another guy that has another v6 that he guarantees has less than 80,000 miles on it and doesn't need a rebuild, he wants $500 for it, I'm gonna go check it out soon. Thank you for all the info..... For the motor mounts, can u explain a bit more? Posted via Mobile Device |
#7 | |
Post Whore
http://67-72chevytrucks.com/vboard/s...d.php?t=574261 The Napa mounts are the ones you want. Pay close attention to the perches as well.
#8 | |
https://losangeles.craigslist.org/la...708436450.html $500 might be too much? Hmm well I have to see it, out here in Cali everything is expensive lol Posted via Mobile Device |
Post Whore
Find out if it's a 351C, E, or Magnum. The Magnum is the most desirable. Bigger 2 barrel, heads, and manifolds. If it's a solid motor $500 isn't to bad I guess. Cheaper than the 478 I am looking at will probably be! haha
#10 | |
The owner told me that the 351 is a 1968. And the 305 is a 66. Both running condition. How do I know of that 68 is one of those you said are desirable? Posted via Mobile Device |
#11 | |
Post Whore
http://www.6066gmcguy.com/engines/Number-305E.jpg
![]() Join Date: May 2007
Another important fact you want to look out for the big truck V6 front timing cover / water pump location is different from a pick up truck V6.
Here is a 401M out of a big truck, notice the magnum bigger exhaust manifolds Here is a 305 in a pick up truck/ you can see the difference in the water pump location
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! Last edited by duallyjams; 08-31-2016 at 07:41 PM. |
#13 | |
Thank you very much for the pictures and the side by side comparison! I think I'm gonna go for the 305. Btw, what in the heck is with all the plaid valve covers on these v6's I keep seeing?? Lol Posted via Mobile Device |
#14 | |
#15 |
Post Whore
If you need help/info rebuilding the beast; let me know as I just got done with one. haha I would recommend subscribing here:
http://6066gmcclub.com/index.php Lotta good info there as we are a v6 club. There are several stories about the plaid valve covers. lol
#16 | |
Thank you you so much buddy, I'll make sure to do that! I'm gonna try to schedule to meet up with both guys and look at the motors soon! I'll be reporting back! Posted via Mobile Device |
#17 |
![]() Join Date: Nov 2012
#18 |
Post Whore
My 66 ran great before I pulled it. SIKE!!!
