08-31-2016, 12:20 PM | #1 |
Chevy with 305?
I'm looking at a 61 CHEVY suburban with a 305 V6 in it.
Did such a thing ever come from the factory? I can see how it might have been a reasonable swap from a 235 back in the day, so maybe an old modification? Brian |
08-31-2016, 01:17 PM | #2 |
Re: Chevy with 305?
I'm guessing an older swap but post up a few photos and let's have a look at how factory-installed it appears.
MusicMan70 1961 GMC Suburban |
08-31-2016, 01:42 PM | #3 |
Re: Chevy with 305?
I'm afraid I only have one picture of it, and it doesn't show much other than that it seems to be a GMC 305 and the heater isn't connected
http://www.brianmcgee.info/piwigo/_d...ccdd407-me.jpg |
08-31-2016, 01:55 PM | #4 |
Re: Chevy with 305?
Here is the v6 from 61 GMC for comparison when I first bought it. Mines has a generator and yours an alternator; That could have always been upgraded but something to consider as far as originality.
The GMC V6 was a GMC thing only unless there is old paperwork requesting the changeover. Unless the person really didn't care for GMC and wanted his Chevy with the new-for-the-times engine, I guess it's possible to ask and pay for it. Also check here on the V6 for the engine number/Letter which will tell you what engine and even year it is. http://www.6066gmcguy.com/EngineData.html
08-31-2016, 03:34 PM | #5 |
Re: Chevy with 305?
The 'burb has a 4 speed (I assume SM420) in it, which means it originally had the 235 Thriftmaster. That had 135 HP net and 195 ft/lb of torque net.
The 305 had 125 HP net and 240 ft/lb of torque!! Talk about a torque monster. I can see why someone would want to swap this. Of course, with the granny-first SM420 (about 7:1) and the factory 3.9:1 rear end, you end up with a 28:1 final ratio in first. LOL. Perfect if your primary requirement is turning tires into smoke. Does the 305 share the same bellhousing pattern? I'm wondering what it would take to swap a correct 283 back into it. |
08-31-2016, 03:37 PM | #6 |
Re: Chevy with 305?
are you sure that it is not a GMC or a chev body stuck ona gmc chassis or parts thereof?
Other alturnative is that someone installed it in there. a lot of things can happen in 55 years ron |
08-31-2016, 03:41 PM | #7 |
Re: Chevy with 305?
Ron,
I don't know. It's got a chevy hood and he's listing it as a Chevy, so I presume that means the title says "Chevrolet" on it, but I haven't put eyeballs on it. The truck is in CA and I'm in IL, which means I have to do a lot of the detective work by remote. B |
08-31-2016, 05:11 PM | #8 |
Re: Chevy with 305?
watch what you buy. if vin# and that don't jive you may have a problem getting it reistered in a different state esp if they do an inspection
1 not many would put a V6 in a chev; not that there is anything wrong with them, that is just the way it is.. if there is a ser# on the frame(top by steering box it will be chev as GMC didn't stamp anything there these years. if there is a ser# on the frame it should match the last set of nbrs On the plate in the door frame. the last 5 or6 digits. I would if you could find someone on the board here who is close by to make a check for you ron |
08-31-2016, 07:54 PM | #9 |
Re: Chevy with 305?
The dash will tell you if the body is a Chevy or gmc. Chevy will have a double hump dash and gmc will have a single hump. Also a gmc will most likely have leaf springs in the rear as where the Chevy will have coils
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
08-31-2016, 09:43 PM | #10 |
Re: Chevy with 305?
60-62 Chevy and GMC's have coils.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
08-31-2016, 10:44 PM | #11 |
Re: Chevy with 305?
Thanks for the info, had no idea. Just shows how different gmc's can be, like how Canadian 60-66 gmc's all had rear coils
08-31-2016, 10:51 PM | #12 |
Re: Chevy with 305?
08-31-2016, 11:25 PM | #13 |
Re: Chevy with 305?
09-01-2016, 07:15 AM | #14 |
Re: Chevy with 305?
It's a 4x4, so leafs all around I think
It has a double hump dash - so Chevy with a GMC engine. B Posted via Mobile Device |
09-01-2016, 09:00 AM | #15 | |
Re: Chevy with 305?
that is how I got my suburban body. it was a 65 gmc on a 84 4 x4 chassis that was brought across the Border into BC. anything that comes in out of province(state in your case) get thorouhly inspected before registr. here. there was nothing the guy could do with it. I bought it for what it was and removed the body and that was really mickey moused on. beauty is only skin deep while ugly goes clear to the bone. ron |
09-01-2016, 09:16 AM | #16 |
Re: Chevy with 305?
Thanks for your advice, Ron. I'm definitely looking for someone to go take a look at it. Fancy a trip to Sacramento?
09-01-2016, 09:23 AM | #17 |
Re: Chevy with 305?
09-01-2016, 11:36 AM | #18 |
Re: Chevy with 305?
09-01-2016, 11:57 AM | #19 |
Re: Chevy with 305?
Good eye, VH!
So it may not have an SM420 in it! More questions to ask. B |
09-01-2016, 12:29 PM | #20 |
Re: Chevy with 305?
09-01-2016, 08:43 PM | #21 | |
Re: Chevy with 305?
It may have a 4 spd now and they just left part of the old 3-spd linkage on the column.
09-01-2016, 09:00 PM | #22 | |
Re: Chevy with 305?
ron |
09-05-2016, 03:22 PM | #23 | |
Re: Chevy with 305?
Ron, You're a genius! The frame started life as a GMC Panel, but the owner wanted something to haul his grandkids, so he swapped on a Chevy body (and titled it as a Chevy to match the VIN plate). So what would the differences be in the frame and mechanical between the '61 GMC 4x4 and the '61 Chevy 4x4? I know the 305A engine, and the clutch. Are there other running-gear differences? I've got a period 283 I could donate if that's all that would be required to make it a Chevy. B |
09-05-2016, 06:59 PM | #24 |
Re: Chevy with 305?
they may have different axles, but you would more than likely upgrade them to newer stuff if you are after pb and ps. not difficult
09-05-2016, 07:07 PM | #25 |
Re: Chevy with 305?
but what is the vin#. bet you the chevy vin# is a 2 whl drive or there is something else was whacky.
did you get any pics of it? ron |
