Old 08-31-2016, 02:14 PM   #1
Smitty
Smitty's Avatar
Talking Door Rubber
I'm about to throw some serious money at the truck. And was wondering what the best replacement seal for the doors would be. Some of the aftermarket stuff used in the past is less than Satisfactory, curling away from cab with age. And any information on a kill type switch and good alarm to help keep the truck in my possession once the work is complete? Any help would be greatly appreciated.
Smitty
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 08-31-2016, 02:26 PM   #2
davepl
davepl's Avatar
Re: Door Rubber
Softseal. Don't slam that door.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-31-2016, 02:27 PM   #3
Fldawg
Fldawg's Avatar
Re: Door Rubber
soft seal
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 08-31-2016, 02:32 PM   #4
webfoot
Re: Door Rubber
Does nobody like the dodge dakota door seals anymore? I put those on my 71 and it felt like they actually sealed. The factory ones look like all they do is cover up the pinchweld.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-31-2016, 02:33 PM   #5
Low69CST
Re: Door Rubber
I had done some research on this, I had considered using steel rubber. Has anyone used them?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 08-31-2016, 03:02 PM   #6
1968aj
Re: Door Rubber
I have installed 2 sets of the new precision push on seals. I will never use the glue on style again. easy install.
1968aj is offline   Reply With Quote
Old 08-31-2016, 03:16 PM   #7
BrianG
BrianG's Avatar
Re: Door Rubber
I just put the NEWEST precision push on seals on my truck as well. I agree, they are super easy to install, seem to seal well, I don't have to slam my doors and they look good. They newest version has the mitered corners also so you don't have to deal with that like their first push on seals had.
BrianG is offline   Reply With Quote
Old 08-31-2016, 03:23 PM   #8
BugzC10
BugzC10's Avatar
Re: Door Rubber
X2...I just installed a set of them. Got them through GMC Pauls. I still have to slam the doors with the windows up.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 08-31-2016, 04:49 PM   #9
Sklptrljay
Sklptrljay's Avatar
Re: Door Rubber
I used some seals from an early 90's junkyard chevy pickup. Cleaned up nice and seal very well. I do have to slam the doors though.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 08-31-2016, 05:34 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Door Rubber
X2. Got mine from Wes at Classic Heartbeat. The reason the door has to be slammed when windows are up is because they actually SEAL!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
