Old 08-31-2016, 03:44 PM   #1
DrivingAC10
replacing stock air cleaner with performance model
I searched but couldn't find a thread on this . . .
So I want to convert a stock air cleaner on my '70 C10 w/350 but it looks like there will be some vacuum lines that won't have a place to go. So what's a guy to do? There's one that goes from the back of the carb to the flap thing in the air intake that is the one I'm concerned about. Otherwise the breather goes in the now unused hole in the valve cover so that makes sense.
Sorry for the ignorance, but i'm a little concerned about screwing something up.
DrivingAC10 is offline   Reply With Quote
Old 08-31-2016, 03:57 PM   #2
webfoot
Re: replacing stock air cleaner with performance model
You'd just cap that vacuum port on the carb as it would no longer be needed.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-31-2016, 05:57 PM   #3
Grumpy old man
Grumpy old man's Avatar
What do you want for the old junky stock aircleaner ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
