Old 08-31-2016, 05:08 PM   #1
bradnree
too much power steering assist
I have a 1985 Chevy 350 with power steering. It has too much power assist on the steering. I can freely spin the steering wheel. WHAT IS THE FIX ??
brad
bradnree is offline   Reply With Quote
Old 08-31-2016, 05:30 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: too much power steering assist
You might have better luck in the 73-87 message board...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-31-2016, 06:05 PM   #3
bradnree
I have taken your suggestion. I have a 1968 there is the confusion. brad
Old 08-31-2016, 07:13 PM   #4
firedemon
I read something on here somewhere that the newer pumps have that effect maybe an older pump will fix it maybe someone who knows for sure can help more
firedemon is offline   Reply With Quote
Old 08-31-2016, 08:09 PM   #5
palallin
Welcome to the world of GM: heavy assist has long been a quality of their products.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-31-2016, 08:14 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Here's your issue. You probably have a 68 PS box. The 68-72 PS gearbox was 4 1/2 turns lock to lock (LTL). Later models went to a different ratio in the PS Gearbox, it is 3 1/2 turns LTL. The 68-72 has always been too soft or mushy for me, but even more so since most modern cars use R&P. I used a 76 box in mine and it feels much better to me. The original was so easy to turn in these trucks you could do it with your pinky. Keep in mind that if you go to a later box, they changed the hose fittings at some point and you will want to have the right ones. The hex nut on the back of the pump is interchangeable. There are some good threads on this if you do a search.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
