Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 08-31-2016, 07:58 PM   #1
BlueDiver
07 2500HD Rear end thunk
My 2500 has a pretty significant thunk in the rear end when rolling away from a stop. It happens so often I slowly roll forward and keep RPM down until I feel the thunk then drive like normal. Annoys the crap out of me and the poor soul behind me at the light. After searching the net it looks like this is a widespread issue.
Is there a permanent fix for this yet or is it just something I have to deal with? I've heard mixed reviews. Any help would be great!
Thanks,
Don
BlueDiver is offline   Reply With Quote
Old 03-14-2017, 03:34 PM   #2
Deer_hunter_088
Deer_hunter_088's Avatar
Re: 07 2500HD Rear end thunk
ttt. could be u joints? or somethin like that?
1967 GMC C25 305 V6
1969 K20 CST
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2001 Silverado 2500hd 8.1L
2003 Silverado 2500hd Crew cab
Deer_hunter_088 is offline   Reply With Quote
Old 04-01-2017, 10:41 AM   #3
slow72
slow72's Avatar
My 10 does the same thing. It started after i had the driveshaft out to grease the u-joints. I've been told it is the slip yoke in the end of the transfer case. I've removed and greased the splines liberally and it got a bit better, but still there.
1972 GMC LWB, 250, 4sp
2010 GMC Sierra 6.6 CCSB
slow72 is offline   Reply With Quote
Old 05-09-2017, 09:41 AM   #4
KShortell
KShortell's Avatar
The splines on the slip yoke at the transmission and/or transfer case will do this on occasion, particularly after a hard stop. This is more of an issue on trucks with longer or two-piece driveshafts and has been since at least the 70s. There is a special, thick grease that GM uses to quiet it down. It is blue and often referred to as "Smurf" lube or something like that.
I've been fortunate that my '08 Silverado doesn't really do this. My old '86 Suburban sometimes would.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
