Old 10-06-2003, 09:06 PM   #1
doc70sub
doc70sub's Avatar
33" tires on a 2wd?
Anyone here running 33x12.50 tires on a 2wd 67-72 GM trucks or Subs? Pics & info are appreciated.....
Thanks!
Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 10-06-2003, 09:15 PM   #2
highboy_04
highboy_04's Avatar
they will fit on a 3/4 ton. i believe the biggest tire on a stock c10 would probably be a 31.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 10-06-2003, 11:26 PM   #3
jescates
jescates's Avatar
How about 31X10.5 on 15'' rally's.
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline   Reply With Quote
Old 10-07-2003, 05:16 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Randy 70c-10 has a 3/4 ton 2wd w/ 33s and I believe his GMC has 31s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-07-2003, 06:56 AM   #5
Krue has then on his 1/2 2WD GMC short step (4wd ralley wheels though). They work, but I would have power steering for sure. I wouldn't be surprised if it is origninal shocks, let alone the springs. (Sorry Krue had to be silly somehow)
Here is a shot he posted a while back right after he put them on.
Old 10-07-2003, 08:20 PM   #6
Hutch
Hutch's Avatar
doc70sub
These are not 33's but they are mounted on a stock 1/2 ton 2wd.
They were on it when I got it and have since been removed.
No problems with rubbing at all.
These are 31.5 x 10.5 BFG's on 15x8 wheels
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-07-2003, 08:56 PM   #7
BigBlack68
Negative Camber
BigBlack68's Avatar
i got 33x12.5's on mine
68 c20
64 cadillac coupe deville
64 cadillac sedan deville
two 84 50th anniversary nissan 300zx tubos
98 S-10 ex-cab,my 4 cyl daily driver
BigBlack68 is offline   Reply With Quote
Old 10-07-2003, 09:30 PM   #8
pa_snowman
31 x 10.50 on 15x8 wheels with stock suspention on mine. this seems to be the most common set.
I know this tire and wheel saved me when i wrecked my 67, the wheel took the impact which tore the lower a-arm off and bent the frame and lower cab. remember concrete dosen't give but this tough old truck allowed my son and i to walk away with only a minor scratch from the mirror bolt. I AM GOING TO REBUILD THIS TRUCK!!!
jim gallagher
pa_snowman is offline   Reply With Quote
