Old 09-02-2016, 10:48 AM   #1
hdixon
Bezel Dash Gauge Install
I have question for anyone that can help I just purchased a 1969 C-10 step side SWB and in the process of replacing the dash cluster I need to know how do the temperature gauge get hooked up and also the battery gauge to the dash bezel can anyone help me out
hdixon is offline   Reply With Quote
Old 09-02-2016, 05:21 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Bezel Dash Gauge Install
Bump to the top.
LockDoc
Leon
Old 09-02-2016, 05:52 PM   #3
66clow
66clow's Avatar
Temp guage answer
http://67-72chevytrucks.com/vboard/s...d.php?t=414053
Both go thru the wiring harness into the dash panel.
66clow is offline   Reply With Quote
Old 09-02-2016, 05:55 PM   #4
leftybass209
leftybass209's Avatar
Originally Posted by LockDoc View Post
Bump to the top.
LockDoc
Aww Lockdoc, you know the answer!!!
Hdixon, the gauges are mounted to 1 of 2 separate rounded-edge rectangular panels. Those panels are mounted to a larger tin that the speedometer, fuel gauge, and/or tachometer mount to. The Amp gauge is connected using a printed circuit board (PCB).The oil gauge is connected to the engine via a copper (or aftermarket plastic) tube, which attaches to an engine oil feed passage (next to the distributor on V8s). The water temp is also connected to the PCB.
I'll try to find some pictures.
leftybass209 is offline   Reply With Quote
Old 09-02-2016, 06:04 PM   #5
66clow
66clow's Avatar
Oil http://67-72chevytrucks.com/vboard/s...d.php?t=517606
Temp http://i718.photobucket.com/albums/w...1/identify.jpg
Old 09-02-2016, 10:50 PM   #6
LockDoc
LockDoc's Avatar
Yeah, I know, I moved his thread from the Suburbans & Panels forum to here and I wanted to get it back to the top. We were leaving to go out for pizza & a movie so I didn't have time to answer it. Thanks for saving me guys...
LockDoc
Leon
Old 09-02-2016, 10:56 PM   #7
gable74
gable74's Avatar
LockDoc
What did you see?
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline   Reply With Quote
Old 09-02-2016, 11:49 PM   #8
LockDoc
LockDoc's Avatar
Originally Posted by gable74 View Post
What did you see?
Not to hijack but the wife and I go out every Friday Night for pizza and a movie, no matter what's showing. Tonight we saw "Pete's Dragon"..... Good movie!
LockDoc
Leon
