Old 09-02-2016, 01:21 PM   #1
So.Cal.Chevy
Front axle swap question
Will a front axle from a 1982 suburban 3/4 ton 4x4 bolt up to a 1972 suburban 1/2 ton 4x4? If not, what years are compatible? Im want to change my 1/2ton over to the 8lug axles. Thank you in advance for any help.
Jonathan:
1972 GMC 3/4ton Suburban
1972 Chevy K2500 Suburban 4x4(sold)
1972 Chevy Beauville Sports Van(sold)
So.Cal.Chevy is offline   Reply With Quote
Old 09-03-2016, 12:06 AM   #2
ChopsawSurgeon
ChopsawSurgeon's Avatar
Re: Front axle swap question
As long as the axle hasn't been modified, it is a direct bolt in. Gm kept the same spring perch width for quite a few years, even when they switched to the Corporate 10 bolt front axle. Just make sure you match the axle ratios for the front and rear axles and you should be fine.
1996 Chevrolet K1500 (daily runner)
1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!*
ChopsawSurgeon is offline   Reply With Quote
