Old 09-02-2016, 04:53 PM   #1
Dannyboy1966
Dannyboy1966's Avatar
1986 Fuel tank shroud
I have read about the damage these covers around the fuel tanks can cause. The previous owner had even warned me not to use the driver side tank because it had a leak. Till now, the passenger side has started a small leak so I have ordered a pair of tanks to replace the ones I have. In the mean time I figured I would go ahead and drop the driver side tank cover to see how bad it was while I was waiting. OMG!!!!!! This is what I found!!!!Name:  DSCN0988.jpg
Dannyboy1966 is offline   Reply With Quote
Old 09-14-2016, 12:36 AM   #2
lime1982
Re: 1986 Fuel tank shroud
Wow
lime1982 is offline   Reply With Quote
Old 09-14-2016, 09:43 AM   #3
tucsonjwt
I would leave those plastic rock guards off, because they trap dirt, water, debris, etc., and result in just what you see.
tucsonjwt is offline   Reply With Quote
Old 09-14-2016, 10:02 AM   #4
gmachinz
That and with modern priming/painting methods, a properly done set of NEW gas tanks should never do that again. I'd actually like to see a company offer plastic replacement tanks like new cars/trucks have-Id prefer to go that route.
gmachinz is offline   Reply With Quote
Old 09-16-2016, 03:25 PM   #5
Dannyboy1966
They do make the plastic tanks, but the cheapest I have found are almost $300 each. I've just made a couple sheet metal shrouds to put in front of the tank to protect it, along with rubber coating the tank.
Old 09-16-2016, 06:46 PM   #6
tucsonjwt
I have seen a couple of off road guards for 4WD squares that I think were a factory option. They were just a flat piece of 1/8" metal that was open on all sides so debris could drain out and you could get a hose in between the tank and guard to clean it. The may have had an upturned section in the front but I don't remember exactly now. I still favor no guards at all.
