Old 09-03-2016, 08:52 AM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Large Flange Fender Bolts
Just some info on new fender bolts if your looking for them. The ones I find in the "kits" are not the "large flange" bolts. So if you would like the larger flange style bolts you can get them from Dorman products #700-302 they sell in 25 count (5/16"). Or a vendor on ebay called theboltbarn.
The bolt barn are not dog point but the Dorman ones are, Dorman are black oxide and the bolt barn are clear zinc. The bolt barn have them in 3/8" and 5/16".
Old 09-03-2016, 08:18 PM   #2
Blue666(2)
Re: Large Flange Fender Bolts
Thanks Master Chief for the tip on the bolt sources.
I had to research dog point. Found it here.
(https://www.boltdepot.com/fastener-i...rminology.aspx )
Blue666(2) is offline   Reply With Quote
Old 09-03-2016, 11:23 PM   #3
Grandpa54
Grandpa54's Avatar
Subscribe
Grandpa54 is offline   Reply With Quote
Old 09-04-2016, 07:54 AM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
For just about ANY GM type body bolt,, check out page 19-20 of the Auveco catalog .The body bolts with the loose washer, and the ones with the threaded threads spiraled down to a point,, it's amazing how many different bolts GM used to tut these things together over the years.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-04-2016, 08:32 AM   #5
darkhorse970
darkhorse970's Avatar
Good info, thanks.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 09-04-2016, 11:10 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
So we need a LIKE button because this has to be one of the best posts to come up. Thanks for sharing and I shared the link on my Facebook with all my car buddies.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-04-2016, 11:51 AM   #7
wahl4m
i use shoulder bolts all the time on hod rod or truck stuff /also like the hardened flange -locking nuts !! most guys building stuff use the "plastic lock nuts " that only last i time -on & off !! i always buy off the "net" very cheap and have them the next day in most cases PLUS a lot cheaper than a hardware store or fastenal and my man there almost gives them to me !!
wahl4m is offline   Reply With Quote
Old 09-04-2016, 12:19 PM   #8
Kenfuzed
Kenfuzed's Avatar
A long time ago I bought the oversized head style from bolt depot. As mentioned these don't have the dog point as with the Dorman but I recall when pricing them back then that these were much less expensive too.
https://www.boltdepot.com/Flange_bol...e_5_steel.aspx
Recently found a guy who sells bolts at all the local swap meets (Pomona, Long Beach) that had the original style black oxide type but I don't think he's online.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 09-04-2016, 03:21 PM   #9
The Rocknrod
Moderator
Awesome find. I use Bolt depot all the time and missed that entirely. Thanks.
Edited - https://www.boltdepot.com/Flange_bol...l_5_16-18.aspx
