Old 09-03-2016, 01:00 PM   #1
86dean63
B-47 bearing help
Recently purchased a 63 C20 it's a two wheel drive 8 lug. Whent to replace the front outer wheel bearings and they are big roller ball bearings with a part number of B-47, called the local parts stores and then some, everyone knew what I was looking for but nobody has anything in stock and can't order them. I need to find a replacement set or a interchange bearing. Anything would help thanks
86dean63 is offline   Reply With Quote
Old 09-03-2016, 01:14 PM   #2
padresag
Re: B-47 bearing help
is this what you are looking for?
http://www.oreillyauto.com/site/c/de...0055&ppt=C0337
make sure that it is the ball bearing one that you want and not the roller needle koyo or torrington bearings
ron
padresag is offline   Reply With Quote
Old 09-03-2016, 03:47 PM   #3
86dean63
Yes that is the bearing that I'm looking for how ever they are out of stock completely
Old 09-03-2016, 05:09 PM   #4
jtrichard
Some thing may NOT be right on your front end 62 was the last year for ball bearings 63 has timken type bearings
jtrichard is offline   Reply With Quote
Old 09-03-2016, 05:24 PM   #5
padresag
there are more place to look for it. you just have broaden your horizons a little. if you are going to keep the truck you will have to learn how to search for these things. there are more than likely quite a few places around your area that supplie brgs other than automotive. that brg may have industrial or farming applications. there should be independent bearing house around
ron
Old 09-03-2016, 05:43 PM   #6
padresag
ron
here are some bearing suppliers in your area
https://www.google.ca/webhp?sourceid...s%2C%20georgia
I would check your vin # to make sure that you have a 63. in some places if inventory was not sold until the next inventory year they got classified as the current year. someone may also have changed things around and going by bearing # is usually positive for what fits. the timkens are usually less expensive than the 60-62 frt ball brg wheel brgs
ron
Old 09-03-2016, 05:53 PM   #7
jtrichard
TRY these guys http://www.locateballbearings.com/
Old 09-04-2016, 12:30 PM   #8
61K10
61K10's Avatar
rockauto lists it for a 62 but not 63
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-04-2016, 12:42 PM   #9
Brad54
Brad54's Avatar
If you go to a bearing supply place (industrial supply house), and measure the ID of the race, and the OD of the bearing housing, and the overall width of the entire assembly, that's pretty much the critical dimensions you'll need. After that point, you can replace the ball bearing with a roller bearing of those dimensions.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-04-2016, 03:00 PM   #10
padresag
-Brad
if you look closely at the b75 you will notice that the inner race is different on either side causing a problem perhaps in converting it to a timken.look at the 2 pictures in the link
ron
