![]() Join Date: Jul 2015
iNSULATION
Hey Guys
I am in the process of taking the old skins from doors and installing new skins. Question-Anybody done this lately and if so what type insulation should I buy. And can I put insulation on both insides of the door. Thanks John |
Re: iNSULATION
if it was mine and I had it apart I would do both sides it will make the door a little heavy but I think it would be worth it . you can get sound deadner kits on ebay cheap
Re: iNSULATION
There is just about enough room in the doors, and behind the door panel to do whatever you want. Most recommendations from those that install that stuff recommend not covering the entire surface. However, there are those that do cover the entire surface, and I can't tell the difference.
