09-03-2016, 10:22 PM | #1 |
Wire on trans
Maybe someone can help me. I have a 1979 chevy blazer. On the trans/ transfer case is a wire that is plugged into the trans shifter linkage. I believe it is to let you know when the 4 wheel drive is engaged. I have the wire that is attached to the trans an I think it goes up through the shifter cover and goes somewhere. That is what I want to know, where does the other end go and what does it connect to? I will get pictures later. Thanks, John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
09-04-2016, 07:53 AM | #2 |
Re: Wire on trans
If its the 4wd indicator it goes up the dash, lights up when put in 4wd.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
09-04-2016, 09:15 AM | #3 |
Re: Wire on trans
Thanks, would anyone have a diagram or drawing of where the wires run?
I have the one connected to the trans but that is it. From that point I need to know where to run the rest. Thanks b454rat for your info. John
