Old 09-05-2016, 05:58 AM   #1
DJ_Baar
Question Eaton H052 Differential Oil?
'67 Chevy C20, Eaton H052, 4.11 gears. Trying to get this right:
* Correct capacity of oil?
** Do I need a friction additive/modifier like LS additive?
Factory manuals were written before synthetics and now also list with friction additive. I grabbed Mobile 1 Synthetic Gear Lube, LS 75W-90 before I realized what "LS" meant.
DJ_Baar is offline   Reply With Quote
Old 09-05-2016, 10:48 AM   #2
truckster
truckster's Avatar
Re: Eaton H052 Differential Oil?
You don't mention a posi, so you probably don't need a friction modifier.
It's been long time since I had a HO52, so I don't remember the capacity.
truckster is offline   Reply With Quote
Old 09-05-2016, 12:07 PM   #3
old Chevy guy
old Chevy guy's Avatar
Pour it in the fill plug till it runs back out.
old Chevy guy is offline   Reply With Quote
Old 09-05-2016, 12:41 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Mine took exactly 3 quarts, and I used the same stuff you bought. "LS" works just fine in an open diff, btw.
fwiw, use Permatex 81182 with a gasket to seal it all up. It's made specifically to work with gear oil.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-05-2016, 12:48 PM   #5
Shaky
Six in a row makes it go...
Shaky's Avatar
Just make sure it's GL-5 rated oil.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 09-05-2016, 02:48 PM   #6
truckster
truckster's Avatar
Yeah, I probably should have said that. You don't need it if you don't have a posi, but it won't hurt anything, either.
Old 09-05-2016, 03:13 PM   #7
DJ_Baar
Thank you Guys.
Also found this http://67-72chevytrucks.com/vboard/s...d.php?t=477844 that seams applicable.
Last edited by DJ_Baar; 09-05-2016 at 03:15 PM. Reason: forgot something to mention
