Old 09-05-2016, 06:25 PM   #1
mpierce9
Turn signal wiring and blowing fuse
Good afternoon. I have a 1975 Chevy Blazer. When the left turn signal is engaged the fuse blows. The right turn signal works great, zero issues. The left turn signal uses a Yellow wire. I have come to this conclusion because the right turn signal works great and will NOT blow the fuse. The fuse only blows when the left turn switch is used.
I assumed a short directly to ground in the yellow wire but I'v been unable to find one.
Any advice?
mpierce9 is offline   Reply With Quote
Old 09-05-2016, 08:04 PM   #2
TKCR
TKCR's Avatar
Re: Turn signal wiring and blowing fuse
I had this issue too. The wire casing gets dried and cracks, exposing the wires. So it is shorting out because it's touching metal on the inside of the column. I saw how bad mine was, when i changed out the turn signal stalk with a new one. I had several places were the wiring was exposed.
I wish I had taken a picture of it, I could have posted it.
Old 09-05-2016, 08:17 PM   #3
franken
Take the bulbs out and see if it blows. I bought a truck w/ aftermarket front signal sockets and the cheap things would short. After that, its tracing the wiring. Pain in the rear...
franken is offline   Reply With Quote
Old 09-05-2016, 10:28 PM   #4
hatzie
Moderator
hatzie's Avatar
Ive seen this on several GM Saginaw columns. If the insulation is breaking up change the turn signal switch. If the Hazards blow the fuse then it's a good guess that it's in the column.
The other place to look is the bulbs. Take all four out and see if the fuse blows with no bulbs in place. I've had cheapies short internally.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
