Old 10-07-2003, 12:31 AM   #1
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Exclamation Anybody with a slammed truck have u-joint problems?
I'm wondering when i lower my truck even more if i am going to have any premature u-joint wear. I have a single driveshaft but the driveshaft u-joints have 2 different cup sizes for each u-joint so they were about $50 each! So i don't want to blow through them left and right. Is there a certain angle they should be and what is the maxium angle they can be before they start to wear really fast?
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 10-07-2003, 05:17 PM   #2
SCOTI
SCOTI's Avatar
My beater 68swb w/1pc driveshaft has @ least a 4/6 drop & I haven't had any u-joint issues in 3+yrs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-08-2003, 07:40 AM   #3
VTKidder
If anything, it will make u-joint wear better, because you are making more of a straight shot from the rear end of the tranny to the yoke on the rear end.
Trucks with huge lift kits tend to be rough on u-joints because of the sharper angles down from the tranny to the rear end.
VTKidder is offline   Reply With Quote
Old 10-08-2003, 06:29 PM   #4
PJ_STYLES
PJ_STYLES's Avatar
Exclamation
Oh ya duh me! For some reason i thought the angle of the drive shaft would get worse not straighter. Good call VTKidder. Lower i shall go then.
Old 10-09-2003, 06:14 AM   #5
VTKidder
You're forgiven....carry on.
