09-06-2016, 02:57 PM | #1 |
55-59 Windshield dimensions
Wondering if anyone has a schematic (if it exists) of the dimensions of the windshield opening for a TF. Having a bit of trouble getting winsdhield in after total restortation and Id like to me sure the dimensions of the opening are correct. Thanks in advance!
09-06-2016, 04:32 PM | #2 |
Hollister Road Co.
Re: 55-59 Windshield dimensions
Try fitting it without the rubber. It should have about 3/16 to a 1/4 all the way round
09-06-2016, 07:01 PM | #3 |
That is a toughie big time! Coming up with dimensions you could measure would be damn hard being the shape that it is.
Do as dwcsr said, you and someone else hold the glass in place without the rubber and there should be about a, 3/16" gap all the way around. Look at how the rubber is made and where it fits and get an idea of where the glass sets. Setting these windows is a bit of a wrestling match and the rubber seems too big. It takes some gentle/tough dancing to get it in. Check out this thread I made on the subject of tools for an idea. These tools made the job MUCH easier! http://www.hotrodders.com/forum/wind...ls-360386.html Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-07-2016, 01:42 AM | #4 |
when I welded the rear cab panel into my 57 I used a couple of pieces of the old rubber to hold the window in place as I work alone. worked great.
09-07-2016, 08:18 AM | #5 |
I posted this on Denee's build a while back. She was having trouble getting a standard size windshield to fit her cab. As far as I am aware my cab has not been modified. I am not saying mine is right, just throwing this out there for reference. Eventually I will put new glass in my cab, then I will know if a standard windshield for 55-59 fits.
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1 |
09-07-2016, 12:54 PM | #6 |
if you need to increase the windshield opening...
we used a porta power to jack on the bottom of the S on the a pillar passenger side is braced (where we jacked) while we spread the drivers side blue line is an exagerated start point, purple is the new body line the guy marked ''hero'' is an old school body man be careful, not sure how you'd recover from an overjack
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-16-2016, 12:55 PM | #7 |
I have found the "new" windshields do not fit very well. I ended up breaking one when I tried to install it after messing with it for over an hour. I ended up digging through my pile of original ones, found a decent one and had it installed in about 15 minutes. The new windshield was way thinner.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
09-17-2016, 09:50 PM | #8 |
I had perfect luck with how the new windshield fit in my '57. Couldn't have asked for better.
I bought it from my local auto glass company. |
07-29-2019, 07:51 PM | #9 | |
Hey Roger, I followed your build - amazing work. What brand of windshield gasket do you use? I have the same windshield - bought locally from Apple auto Glass- having. Slightly hard time with install. Did you install your windshield yourself?
1967 C-10 250 I6 w/ TH350 3.08 10 bolt HUGGER ORANGE aka "The General" '57 GMC short step REGINA SPECIAL 2013 CREW CAB SILVERADO 5.3 6 SPEED Z71 WHITE DAILY DRIVER "When you have eliminated the impossible, whatever remains, however improbable, must be the truth." ~Sherlock Holmes "Deeds will not be less valliant because they are unpraised." ~ Aragorn |
07-29-2019, 08:55 PM | #10 |
I got my gasket from Brothers. I don't know what brand they supplied me with. Worked great though.
Yes I did it myself. It was pretty darned easy. One thing I find helpful is to carefully place the glass in the channel first without the gasket. Makes it easy to find the exact center and then make some marks on the body and glass. Otherwise, it's hard to find the exact center without marks once the gasket is installed on the glass. |
