Old 09-06-2016, 05:41 PM   #1
Skunksmash
Skunksmash's Avatar
Should I lube new window regulator?
Bought a new driver AC Delco window regulator with motor. My question is, should I lube the brand new regulator? Its hard to tell if there is any lube actually on there. It feels a bit greasy, but maybe that is just a very thin layer.
Should I use some of that white lithium grease on it before installing it?
Skunksmash is offline   Reply With Quote
Old 09-06-2016, 06:16 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Should I lube new window regulator?
I did, I hosed the rollers and scissor-joints with white lithium grease.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-06-2016, 07:12 PM   #3
tucsonjwt
Can you tell me the AC Delco part number on that regulator with motor? I need to replace the passenger side (right) regulator and motor on my 83, but I see conflicting application years for the same part number from different vendors.
tucsonjwt is offline   Reply With Quote
Old 09-07-2016, 04:49 PM   #4
Skunksmash
Skunksmash's Avatar
My truck is 87 so I'm not sure you need the same part. Maybe, but maybe not. I just went to rockauto and got the one for my truck, yours should be there. It does list the part number as well.
