McGaughy's or DJM????
Hi guys, I come over from the 67-72 side of things, but I have a guy who wants me to lower his 81 C-10. I was looking at kits from DJM and McGaughy's and could not decide. I really liked the McGaughys 93150 kit.
What have you guys had good luck with? He wants like a 5 to 6 in drop. Here is a pic of his truck.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
Diggin The SquareLife
Re: McGaughy's or DJM????
do your self a favor an stay away from djm....cheaply made etc an I wouldn't do mcgaughys also.....I would do western chassis 2.5" spindles and 2.5" springs up front and belltech 6" flip kit with drop shackles and go with belltech drop shocks and pick up some shock extenders to correct the shock angle an take some stress of the mounts I had all this on my 84 but didn't have shackles I used 1" blocks
pic
#4 | |
driving is in my blood
Western Chassis all the way. Mchaughys might be good but DJM is not for sure.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
I'm voting for Western Chassis aswell. i did a 2.5/4 drop with their parts and couldnt be happier with everything
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
resident oilfield trash
I just ordered mcgaughys but I've run them all at one point in time or another. I never had a problem with djm. Only one over ever had a hard time with was chassis tech. I went out cheap and bought that and it was junk. Had to be trimmed to fit
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
McGaughy's - PERIOD .
RIZ |
DJM get the drop from their lower arms yeah?......which creates ground clearance probs?....but can use std spindle setup?.....
Junior Member
I bough the Mcgaughys kit and the front was rubbing the inner fenders. The 2" drop spring are definitely more than 2" and they are spongy. It looks great I just can't drive it with out tearing out the inner fenders.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
yea don't do drop control arms at all which will cause problems etc like ur saying....spindles an springs always
#13 |
there is a cpp drop spindle that allows for clearing a larger wheel. it didn't exist when i built my truck other wise i would be all over it. i would pair that with just about any 2" drop spring. just about all the drop kits for the rear are identical since you are just welding on brackets and flipping the axle and putting in a notch. buy your own nitro shocks. ridetech has a set that will last and look great. dont forgot to do the bushings while the truck is in the air. lowering a truck on bad bushings will result in terrible handling and tracking all over the road. IMO
#14 |
![]() Join Date: May 2005
The McGaughys 93150 is a very good kit. I've used it on 4 different C10's with no issues. I usually run Bell Tech Street Performance shocks and run a 27" tall tire up front.
#15 |
Junior Member
20x8.5 might be 20x8 with a 255/40/20 tire which is 28 inches
#16 |
Post Whore
![]() Join Date: Aug 2014
I did not have a good experience with McGauphys at all their 2" drop front coil springs dropped my front end over 4.5" inches and the camber looked rediculous, their rear hangers and shackles are cheap and flimzy and need washers or spacer to align the leafs properly
they would not accept my return because it was more than 30 days by the way LMC Truck sells McGauphys suspension parts they just don't tell you that, but when the products arrive they have McGauphys labels on them, try something else that is better quality |
#17 |
Post Whore
#18 |
thanks for all the good info guys. I really appreciate it. even though this is not my truck I'm doing it to, I want it to be a nice ride and good the owner. I'm definately leaning towards western Chassie, but I will give the owner the western price and McGaughy's price. Let him decide. I will just try to push him in the better more reliable direction.
thanks
#19 |
I was very pleased with DJM 3" drop spindles. Good quality and super tight tolerances. Their flip kit though leaves a lot to be desired.
I used western chassis for my flip kit with generic ebay shackles.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
#20 |
Another company that kind of recently sprung up (2011) and has been featured in some magazines is CROWN Suspension. they were featured specifically for their square body suspension kits. Being a smaller company you will probably get better costumer service and helping out the smaller company is always a good thing to do. they say lifetime warranties but i dont know anyone who has used them. Im going to use them to drop my 2015 silverado.
#21 |
There prices are high
#22 |
not really though. Crown suspension includes 6/7 drop spindle , spring , flip kit , notch , shackles , nitro shocks = $703.00 McGaughy suspension includes 4.5/6 ← biggest drop offered in a kit spindle , spring , flip kit , notch = $580.99 DJM suspenion includes 5/5 drop ← biggest drop offered in a kit Spindles , springs , flip kit , upper arms = $637.19 McGaughy is really the worst one. after you add in shocks and shackles in order to match crown it is most likely about the same price but not nearly as much drop. so inch per dollar is pretty bad lol DJM doesn't give you a notch or shackles or shocks yet they give you fancy A arms which actually arent needed. Djm claims the c notch is not required but thats if your ok with having 3/4" of up travel. also doesnt give you as much drop as crown. Crown gives you a big drop. the rear drop is adjustable because of the shackles so you can do a 6/5 or 6/6 drop if preferred. all these kits in reality probably cost the same once installed on the truck its really about the conveniance factor and personal preference on the drop height. if i could go back and start again i would go with crown. i personally have a McGauphy kit and it works fine but i had to buy extra pieces that weren't included. it would be nice to have everything arive in one big box and support an uprising american company. IMO
#23 | |
Post Whore
#24 |
my McGaughy suspension came out just fine. however i built my truck back in 2010 so its possible and likely that the product has changes since.
#25 |
to be fair i forgot to do research on Western Chassis
biggest kit offered is a 4/6 kit spindles , springs , flip kit OR leaf springs , drop shackles , notch = $599.98 Seems like a good deal, gives you leaf or flip option, go for flip . still no shocks which will run another 100$ for cheapies and again not as much drop as the crown offers so inch per dollar is not as good. previous statement really only applies to those trying to get really low.
