Old 09-08-2016, 12:12 PM   #1
billetproofcustoms
billetproofcustoms's Avatar
Asbestos or not in these old trucks
Hello everyone,
I have tried to get info on any asbestos containing materials used in these old trucks, I have a 1966 short wide. I have not had too much luck finding solid evidence, but have narrowed it down to the most common "large quantity" suspect materials, which are; the original black rubber/tar floormat, the firewall insulation in the cab, and the undercoating. Now, I know there is certainly a concern with brake dust, and I hope everyone knows that going in, brake dust should be common knowledge..?
My point being this;
I have taken samples of each of those items out of my truck and they are currently at an asbestos testing lab in Dallas for analysis. By this time next week I will know as fact if these 3 items i have listed are "hot"
I will immediately post results here in this thread so everyone here that has asked the question in the past will have an answer based in fact.
IMO, everyone should be aware of any potential health hazards from this stuff before diving in and tearing out something that is harmful to your health.
billetproofcustoms is offline   Reply With Quote
Old 09-08-2016, 04:51 PM   #2
dracko
dracko's Avatar
Re: Asbestos or not in these old trucks
Good idea on the shaving cream
dracko is offline   Reply With Quote
Old 09-09-2016, 07:55 AM   #3
jbgroby
jbgroby's Avatar
IT will be too late for many of us. I had my cab dipped, so I'm going to live forever......
jbgroby is offline   Reply With Quote
Old 09-09-2016, 05:16 PM   #4
61K10
61K10's Avatar
you're going to get acid reflex if you've been dipped---
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-09-2016, 11:36 PM   #5
Praxiss454
Praxiss454's Avatar
Subscribed. Thank you and please do post your results. I'd also be interested to see exact pictures of the material you had tested.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 09-11-2016, 09:30 AM   #6
ironman3452
ironman3452's Avatar
if that is the case what about lead in the paint?
ironman3452 is offline   Reply With Quote
Old 09-11-2016, 11:46 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
And don’t forget about hitting your head when you work on the truck, you could go into a coma.
Or cut your hand (or leg) on the rust and get lock-jaw.
Or slip on the oil (or grease) on the floor and break your hip.
Old 09-11-2016, 03:54 PM   #8
ls60apache
there is also a mat between the roof panels , kinda like thick tar paper.
ls60apache is offline   Reply With Quote
Old 09-12-2016, 05:40 AM   #9
I think you'd probably have to eat all those asbestos containing materials to harm yourself but to each his own.
Old 09-12-2016, 07:09 AM   #10
68panelman
68panelman's Avatar
This is called letting your mind wander a little too much
68panelman is offline   Reply With Quote
Old 09-12-2016, 07:39 AM   #11
60chevyjim
60chevyjim's Avatar
you better sell that old truck just to be safe LOL.
60chevyjim is offline   Reply With Quote
Old 09-13-2016, 07:49 PM   #12
ironman3452
yea I need parts, better sell while you can lol
Old 09-13-2016, 09:00 PM   #13
Praxiss454
Praxiss454's Avatar
Tough crowd. Looking forward to the test results, better to be informed.
Old 09-14-2016, 08:33 PM   #14
Flying Hamster
Flying Hamster's Avatar
Places asbestos will likely be:
Exhaust donuts between manifold and exhaust pipe.
"Cloth" covering on wiring.
Gaskets
Choke tube "cloth" covering.
Brakes.
Clutch.
any white paper insulation in gauges or lights.
Possible pads in gas tank straps.
Bakelite parts like switch knobs, window crank knobs, switch blocks inside switches, starter solenoid insulators and fuse blocks.
It MAY be in seam sealers and caulks from that era.
If it IS in the floor mats or tar coatings, unless you dissolve or burn the mats or tars, you will not release asbestos.
Many of the old paints and primers DO contain lead, which was also used as body filler/solder on the exterior.
Flying Hamster is offline   Reply With Quote
Old 09-16-2016, 12:26 PM   #15
billetproofcustoms
wow, this IS a tough crowd...
I understand that some think that this stuff is nothing to particularly worry about, and some would literally sell the truck if any is discovered. Im not going to have an abatement company come put a bubble over my truck and tear this stuff out with Haz Mat suits...BUT, I work in an industry that has made me keenly aware of the dangers of asbestos, and I do take that seriously, but I'm not they type to sell my truck because of it, I just know enough to want to be aware so I can take the proper precautions that I feel are necessary to ME.
Nothing wrong with that IMO.
@flyinghamster..good list, I was aware of most of these as well. I am primarily focusing on the stuff that I will be "disturbing" by pulling out, sanding, grinding, etc, thus possibly releasing the fibers.
I sent the samples off early week this week, I have not received the results yet, but should have them early next week, I will post results for everyones info.
As far as the specific items i sent off:
1. The firewall mat inside the cab underneath the dash.
2. the original rubber floor mat and the tar like mat underneath it
3. the factory undercoating on the frame/underside of the truck.
Old 09-16-2016, 12:52 PM   #16
VictoriaHardware
VictoriaHardware's Avatar
Thank you. This is exactly the type of thread that needs to be here. More useful than the "Show me your fill in the blank" threads.
VictoriaHardware is offline   Reply With Quote
Old 09-22-2016, 10:50 AM   #17
billetproofcustoms
OK, so the Asbestos testing results are in. These were analyzed by a NVLAP certified/licensed Asbestos testing lab in Dallas TX, using the PLM/DS method.
I took samples of 3 materials as follows:
1. The fiberous brown firewall insulation inside the cab:
NO asbestos detected, The fiberous content is 60% Cellulose, 20% cotton, and 20% Synthetic
2. Black floor mat and tar-like substance it is stuck down with:
NO asbestos detected, The fiberous content is 15% Cellulose
3. Black undercoating under the truck (everywhere):
NO asbestos
good news all the way around!
I hope this helps out for what it is worth.
Old 09-22-2016, 11:15 AM   #18
PGSigns
PGSigns's Avatar
Thanks for getting it tested. All good information.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-22-2016, 11:23 AM   #19
nibulus
nibulus's Avatar
Good info. Thanks for sharing!
nibulus is offline   Reply With Quote
Old 09-22-2016, 11:42 AM   #20
dracko
dracko's Avatar
Awesome thanks for doing that man. The thought definitely crossed my mind when I was tearing out the firewall insulation.
Old 09-22-2016, 03:47 PM   #21
nxtruck
nxtruck's Avatar
Thank you for posting these results!!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 09-22-2016, 04:44 PM   #22
jbgroby
jbgroby's Avatar
Old 09-23-2016, 09:48 PM   #23
Praxiss454
Praxiss454's Avatar
Old 09-24-2016, 05:50 PM   #24
Heater63
Heater63's Avatar
Thank you! Good to know!
292 + TKO500
Heater63 is offline   Reply With Quote
Old 09-29-2016, 01:13 AM   #25
64jmb
64jmb's Avatar
Thanks for letting us know. Great information! I own a 66 C10 Short wide bed Fleet side custom cab myself!
64jmb is offline   Reply With Quote
